Results 1 to 8 of 8
Thread: HomeMade powerSupply with Noise ...
    Jul 2001
    France
    Question HomeMade powerSupply with Noise ...
    Hello, i have built a AT-PS but i have some problems with.
    I use MAX787 for 5V, MC78T12 for 12V and LM2575T-12 for -12V (see datasheet if you want schematic ...) and a L7905.
    My main problem is the noise. There is a noise. What should I do for this.
    Thanks ...
    PS. If anyone knows how to increase sound under linux, i would be interested ...
    Nioux [email protected]
    Jul 2001
    The Netherlands
    Post
    Hi, could you post your schematic? for two reasons..
    first: this way people have some more insight to what you're talking about
    second: I'm really interrested in how you made this, so I can copy it of you
    cheers!
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
    Dustin Haug
    Guest
    Post
    What kind of noise is it? Can you describe what it sounds like (i.e. a whine or hum). How do you have it connected to the car's electrical system?
    Jul 2001
    France
    Post
    Hello
    For marsjell : here is the url where I upload the schematic : http://www.nioux.fr.fm/mp3car/alim/alim.htm ( alim in french says PowerSupply )
    If you make the same with changes, email me please. i would like to improve it ...
    For Dustin Haug:
    Sorry I'm french and don't understand whine or hum.
    There are two noise. A helicopter noise in the background. and another noise only when the engine is on.
    Thanks ...
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Post
    Hi,
    As you said on your website (where the 12v rail is.) The psu probably needs 14v to operate.. True, It needs 14.2v to be exact...
    Quote from the datasheet:
    The input voltage must remain typically 2.2v above the output voltage even during the low point on the input ripple voltage
    I think this 'helicopter' sound is the hard-disk spinning, I heard it once, but I don't know what you can do about it.. maybe get a better soundcard, as this one does not 'isolate' the sound too well, noises from the computer are picked up by the soundcard.
    I don't know about this hum. Normally you would have a hum like this when you are using an inverter. (grounding all electronic part to the SAME ground usually solves this).
    But I think you are using your own dc-dc-psu (if not, let us know). Still.... Ground everything to the same spot and make sure it is a decent ground.
    If this doesn't eliminate the noise you could always use a Ground-Loop-Isolator to remove the noise from the audio-signal-cable, but this is not preferable as this is just a solution to the noise, but it doesn't solve the origin of the noise.
    Hope this helps you out !
    Greetz
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Jul 2000
    Jackson, MS, USA
    Post
    Originally posted by Nioux:
    <STRONG>Hello, i have built a AT-PS but i have some problems with.
    Thanks ...
    Nioux [email protected] </STRONG>
    YOur distro should of came with a program called "aumix" run it and turn up the volume on PCM and mixer/master.
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    Jul 2001
    France
    Post
    Hi and thanks everyone.
    I have two power supply ( not all in the same time ). I have my own PS and the Sproggy One.
    My hard disk is very old (it's for tests) but with a AC-DC PS (250V in Europe), there is no noise. Maybe with the DC-DC PS, it could produce problems.
    What is a Ground-Loop-Isolator ? Is it possible to built one ?
    If I ground the GroundWireSound, could it remove noise.
    My card is an 5 years old Sound Blaster Pro 2
    If anyone has no problems withthis card, tell me.
    Thanks ...
    Nioux
    Jul 2001
    France
    Post
    I forgot to say that with the Sproggy PS, there is a Spoutnik Noise, bip, bip, bip, bip. And this noise doesn't depend on the Autoradio Volume ...
