Results 1 to 2 of 2
Thread: Added Power Filter Circuit, but Reboots on Crank
    Mar 2005
    I'm running a M1-ATX on an Xbox and I can have it survive crank...however, I have quite a bit of noise on the power side of things. I've grounded out the mobo and improved things a bit...I tried using a power filter and it decreased dramatically (still a bit, but can't seem to isolate the issue)...anyways, when i added the power filter the M1-ATX can't survive crank anymore. I am assuming this is the case because the wires from the filter are not nearly as large as the ones I'm using coming from the battery...so the current can't travel through it...so are there "beefer" power filters out there?
    Edit Title: I didn't mean Reboot, I meant Turns Off
    Mar 2005
    ...anyone?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. BIOS option for EPIA that reboots after power failure?
    By rordog in forum Power Supplies
    Last Post: 12-16-2002, 09:46 AM
  3. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
  4. book pc power supply AC filter
    By enlight22 in forum Power Supplies
    Last Post: 12-14-2001, 06:56 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
