Results 1 to 5 of 5
Thread: Opus Kill Switch
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Opus Kill Switch
    After leaving my car for a week it wouldn't start this morning, I suspect because the USB stuff is still powered when he car is off so my BT adaptor, SoundBlaster USB and GPS sucked some power.
    So, I want to add a kill switch that will enable me to isolate the PC in such cases. Is the best way to just add a switch to the hot wire from the battery to the Opus? Note I am not trying to prevent it from switching on (although this should do that anyway) but to manually preven ANY draw on the battery.
    Do I need a special switch to handle the current draw on this cable? Are they rated like the cable, ie 10AWG?
    Chris.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    switches are usually rated for amperage i believe and its not very hard to find a 15 amp fuse, you could just pull the fuse to the opus....or fuseblock, or flip the switch on a circuit breaker if you have that. This is my method.
    PC Components:
    My work log
    Nov 2003
    Massachusetts
    I have a fuse in the line and a spade connector so it isn't hard to disconnect it as things stand I just think a switch would be more "proper". I'll have a poke around at Radio Shack and see if I can find a neat in line switch.
    Thanks for replying.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why not just "switch a relay"?
    That way, you can find nice looking switch what doesn't have to be 15A or higher.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2003
    Massachusetts
    I think it just becomes too much hassle to wire it up with a relay for little benefit, in this case at least.
  1. Did I Kill My Opus?
    By ukchris in forum Power Supplies
    Last Post: 07-27-2005, 10:18 PM
  2. Opus 90w power switch wire connection question
    By Tim97rs in forum Power Supplies
    Last Post: 05-13-2005, 08:37 PM
  3. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  4. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 02:13 AM
