Results 1 to 10 of 12
Thread: Adding a second battery?
    Nov 2000
    Question Adding a second battery?
    I'm interested in adding a second battery to my car for running my amp and car PC alone (so it won't kill my car battery to listen when the car is off). I know it's not at easy as just adding another battery off the terminals of my regular car battery (I at least need an isolator to stop it from killing the main battery...) What else does it take to put together a little backup power system?
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    All you need is a battery isolator and the necessary cable.
    Aug 2000
    Abbotsford, BC, Canada
    Post
    Just make sure your alternator can handle the extra load. Right, Aaron?
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Nov 2000
    Question
    Almost sounds too easy. My alternator is 110 amp (stock Camero).
    Where would I pick up a strong enough batery isolater (is it a Radio Shack part)?
    Apr 2001
    Portland OR
    Post
    Originally posted by TheDingo:
    <STRONG>Almost sounds too easy. My alternator is 110 amp (stock Camero).
    Where would I pick up a strong enough batery isolater (is it a Radio Shack part)?</STRONG>
    You could use a diode!
    The MBR745 from fairchild semi or www.digikey.com would do the trick. Its only 65 cents. That way when your car is on, the battery is charged to 14 volts and the aux battery is charged to 13.6 volts. No current can flow back into the cars elect system when you start your car or turn it off, and both batteries won't discharge each other. Use more of them if you use a larger battery, each diode can pass 7.5 amps.
    Jeff_
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Jan 2000
    Cool
    Do not parallel diodes and expect them to each carry the same current. There is variation in the manufactur, and some diodes will carry more current than others. These diodes will blow, forcing the remaining diodes to carry even more current. They will then blow. So, you will have a bunch of blown diodes...
    Jan 2000
    Smile
    Originally posted by dos4who?:
    <STRONG>Just make sure your alternator can handle the extra load. Right, Aaron?
    ~m</STRONG>
    True, true.
    May 2001
    Blacksburg, Virgina
    Question
    With a second battery in parallel, could you not use the atx DC-DC converter from industrialpcs?
    i doubt there more than $180 from keypower.
    industrialpcs
    -MJR-
    May 2001
    Blacksburg, Virgina
    Red face
    I meant series, but you knew that
    -MJR-
    Feb 2001
    Kuutinkylä, FINLAND
    Post
    I found from old at-ps doublediode which can handle 30 amps!
    It's MBR 3045
    WINAMPCAR
    Project almost ready
