ATX and AT motherboard
I have a Pine Slot 1 motherboard with both AT and ATX power connections on it. I am currently using an Arise DC-DC to power it throught the AT connector with an Dschmidt Auto ShutOff controller. I was wondering if I could some how use the AT power connector and jumper a wire over to the ATX "Power Good Signal" to trick the MB into thinking it was using ATX. I know ATX Power also has 3.3v, but I figure the MB must have an on board 5v to 3.3v regulator or the DIMM 3.3v RAM would not be working now. Any way the point is I want to trick the MB into thinking is running with an ATX power supply so I can use WIN ME hibernation. Any Ideas?
Pine Mother board
Here is it
This should help u a little
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
