Based on what the book says, the power supply is probably an ATX or a close cousin.Originally posted by mtmsol:
<STRONG>I'm using an MSI Concerto PC, which is a proprietary motherboard and power supply.
</STRONG>
Yup, just one long pair of wires. Voltage will run through the wire when the switch is closed. The voltage and current will be low.<STRONG>
Here's my question: the computer is in the trunk and the switch will be on the dash, so how should I wire this? Because the wires will be about 20ft. long, will I need to run any voltage through this?
</STRONG>
It should work, and since the current will be low, you'll be able to get by with thin wire. Heck, phone wire would probably work. All you need is 2 conductors. If you go to Radio Shack, look for N.O. (normally open) momentary switch.<STRONG>
My thought is that the motherboard must constantly be running a small current to this jumper to monitor for a switch being pressed, so I'm not sure if just running 20ft of wire to a switch will work or not. Any thoughts?
</STRONG>
LinkBack URL
About LinkBacks
