Jeff, PressLab thanks very much for your explinations....![]()
And since we are ****ing off the original tranny, the same winding ratios would work on ATX supplies designed for 240Volt Australian usage too, would it not?
How small is the final powersupply. Can you fit the re-designed transformer back into the ATX case shell..... maybe this is how the ARISE guys build their powersupply units!! hehehehe!
I guess if some schematics were posted, and the ferrite core could be purchased of the size required (it is a core, not a rod?) im guessing you would have the problem solved for us guys like myself still using a PS/inverter setup.....
this is exciting stuff...![]()
LinkBack URL
About LinkBacks
Good thing I had a spare.
