Results 1 to 10 of 12
Thread: Power Managment...
    May 2001
    tustin, So. Cal
    Post Power Managment...
    Currently i have two Sub woofers, two amps, and a 1 farad capacitator. I'm worried about adding in another thing, ( a mini-pc)... do you think my battery and cap can handle all of that?? thanx....
    Looking for Guidance...
    Feb 2001
    Kuutinkylä, FINLAND
    Post
    What kind of amps are they?
    mini pc will take about 8 A so its not so much.
    WINAMPCAR
    Project almost ready
    Apr 2001
    Here, There, Everywhere
    Post
    do you think my battery and cap can handle all of that?? thanx....[/QB]
    The capacitor isn't going to help the situation at all. They are designed to give a reserve of power when the amp(s) need it (for example when a big bass note goes through the system, subs need alot of power) they dont provide "more power" as such.
    Best bet is to get a nice big battery - i usually go for 520CCA batteries since it is harder to flatten the bigger battery, and it is nice to have a nice lot of power during engine startup anyway. Also make sure your alternator is up to the task.
    Project - GAME OVER :(
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Post
    8 Amps! Bloody hell, what do you have in your car? A Craig?
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
    Feb 2001
    louisville,ky,usa
    Post
    A Cray?
    FYI the arise ACE-865 has on the back of it.. 8-16v , 15 amps.
    Go figure.
    I cheat, I own an empeg.
    Meskimen's Law: There's never time to do it right, but there's always time to do it over.
    http://civic.mp3car.com
    Mar 2000
    Portland, OR , USA
    Post
    Personally, I hate amps, so I don't think I'd use that many.
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Well, a computer can't drive car speakers directly, so you gotta have one. Even if you have a head unit, it has an amp inside it. Nescessary evil
    Dustin Haug
    Guest
    Post
    Mike I'd worry more about your alternator than your battery/cap. The more things you hook up to your car's electrical system the more juice it has to provide when the car is running. Remeber that it has to power everything plus charge up all the batteries in the car. So if you upgrade anything consider getting a bigger alternator, but from the equipment you mentioned unless you are running some huge amps or playing your stereo full bore with headlights on, wipers going, and A/C cranked you should be o.k.
    Apr 2001
    Post
    I heard that if you get a yellow-top Optima battery, you need not worry anything about batteries anymore ! Many people I know who have power-thirsty stereo setups and lcds and such use the Optima yellow-top battery. It costs around $180 I think.
    Apr 2001
    Post
    Originally posted by Craig Chatterton:
    <STRONG>Personally, I hate amps, so I don't think I'd use that many. </STRONG>
    I think a few have missed the difference between electrical AMPS, and AMPS as in audio amplifiers within this thread?
