Results 1 to 7 of 7
Thread: DSATX feature request
    Fusion Brain Creator
    Mar 2005
    I'd like to be able to run in standby S3. I can do this manuall by selecting standby from the shutdown menu, and I only draw 150 milliams. I could leave it this way for a week and still not run down my car's battery.
    Problem is, the DSATX cuts power to the MB 90 seconds after the pulse is sent to the MB's power pins, so I only gey 90 seconds of time in standby. 90 seconds isn't quite a week.
    Jeff?
    Apr 2001
    Portland OR
    Quote Originally Posted by greenman100
    Jeff?
    It is already implemented.
    If you'll see this complicated image:
    If you'll notice, one of the parameters is "Enable5VSBOFF" and "EnableSleep"
    If you clear these, it leaves the +5VSB on when ACC goes low and all timers expire. Unit will draw 20mA in this mode, plus whatever your PC draws in this mode..
    Since you got one of the very first units, yours doesn't have this feature, and it isn't feild upgradable. If I loaded the lastest code, your scrambling eeprom and all these other features would be yours.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    I'll wait for all the bugs to be worked out, before I order mine.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Alright, instead of making new thread, I am just stick it in here.
    I am not sure it is a problem/bug or feature, but it is not what I want.
    Description: If everything work accordingly, this post won't be here, but sometime things doesn't work the way you want. When shutting down the PC (ACC OFF, Power pulse sent, blah.... blah .... ), and the PC hang instead of shutting down, DSATX doesn't cut power to PSU. Basically it will run down the battery to "low battery threshold".
    Request/Question: Is there anyway to cut down the power to PSU (I am not using standby) as it should do with normal shutdown? I mean cut off power to the PSU x minutes/seconds after power pulse is sent.
    So far, the PSU is rock solid.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2005
    Quote Originally Posted by MatrixPC
    it's supposed to cut power after 90 seconds
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by zootjeff View Post
    -Jeff
    Do I still have to do this in the latest firmware? I've just enabled 5v (Enable5voff=0), but I didn't disable sleep (Enablesleep=0, I kept 1).
    Thanks!
    Dec 2007
    Danville, CA
    Short answer: you don't have to disable sleep.
    Check this thread:
    DSATX 3 blinks?
  1. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  2. feature request: native gps support
    By liquid_smoke in forum Road Runner
    Last Post: 11-24-2005, 11:37 PM
  3. Feature Request: play song on select
    By badandy in forum Road Runner
    Last Post: 04-05-2005, 09:52 PM
  4. small fp feature request - album art modification
    By therussman2002 in forum FrodoPlayer
    Last Post: 12-01-2004, 12:28 AM
  5. Replies: 5
    Last Post: 08-17-2004, 12:08 PM
