Results 1 to 6 of 6
Thread: Opus 120w problem
    Oct 2005
    Washington
    Opus 120w problem
    Well I've had my carputer in for a few days and I can't figure out whats wrong with it.
    It will power up and run perfectly fine. Until I shut it down. It shuts down just fine too. But after it shuts down it wont power back up unless I unplug the power to it and plug it back in. Then it powers up fine again.
    The opus gives me the 1 blink ever 5 secs before I start it. Manual says that means all is well. After I shut it down and it wont start back up I get the exact same blinking except it is very dim. When I unplug and plug it back in to get it to work i get the full brightness of the led.
    I could put a switch on the power to it but that would be a pain. I would have to run wire to the dash and back(carputer is in trunk).
    Has anyone else had this problem? Anyone know what it is?
    PS Computer runs fin off normal AC psu without having to unplug and plug in everytime.
    Epia Via M12k
    512mb ram
    Opus 120w
    250gb HD
    Oct 2005
    Washington
    no one has any idea at all?
    Epia Via M12k
    512mb ram
    Opus 120w
    250gb HD
    Oct 2005
    Washington
    I guess if no one has any ideas I'll put a switch in the dash.
    Or is there any kind of hardware that can automaticaly cut the power for for a couple seconds when the ACC is turned off?
    Epia Via M12k
    512mb ram
    Opus 120w
    250gb HD
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    try reversing the connection to the power button on the mobo.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Oct 2005
    Washington
    thanks for the reply but I tried that and then it wont even start up the first time.
    I also realised today that the second start up it does get the signal to start and tries but it seems like there isnt enough power output from the opus. Like I said after it shuts down the LED blinks very dimly. Then when you try to start it up again the LED turns on solid but still very dim. I know LEDs take very little power so I dont see why it would ever go dim unless the battery was prettly much dead.
    My idea is that somehow after shutting down the computer the psu power output is changed to almost nothing or it is shorted somehow. But what happens to the opus after power down that would cause a short that would go away after unpluging the power and pluging it back in?
    Epia Via M12k
    512mb ram
    Opus 120w
    250gb HD
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    I have Opus 120w and I could tell you that you definately have a short somewhere. Remove all the wirings and test.
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
  1. Opus power up problem
    By baef in forum Power Supplies
    Last Post: 10-23-2005, 08:00 AM
  2. OPUS 120w - Disable Standy Mode?
    By BoraXP in forum Power Supplies
    Last Post: 09-29-2005, 12:13 PM
  3. 150watt Opus Small connector problem
    By mbkowns in forum Power Supplies
    Last Post: 09-24-2005, 01:49 PM
  4. Opus 150 problem (overloading rails)
    By Craig W in forum Power Supplies
    Last Post: 07-18-2005, 12:16 PM
  5. OPUS 150 Problem FIX
    By titaniumkingpin in forum Power Supplies
    Last Post: 02-25-2005, 08:31 AM
