Actually it is exactly the same as using the 2587 only it is a much smaller package. You could probably get 2 amps @ 15 volts in the 8-14 volt input range. You have to look at the application circuit, you will see that there is vin, then there is a coil, then there is a diode, then there is the output. you can think of the coil as just a wire, Your input has to be less than the output by .6 volts or so. It even says it in the data sheet, sorry for the bad news.. :-)Originally posted by Machs_FueL:
<STRONG>What about something like this?
The MAX771 uses a MOSFET to get 12v @ 1A from 2 to 16.5 V
but this would be better the stepping up and then down right?</STRONG>
Jeff_
LinkBack URL
About LinkBacks
