Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Making a PSU
    Jul 2000
    Ottawa, Canada
    Post Making a PSU
    So I was going to try to make the newest Sproggy (2.5) PSU but found the transfomer expensive a a little hard to find.
    I was all set to peice together something from examples on numerous site but then i found the sproggy 2.0 (older).
    So i cut and pasted on the power good section from the 2.5, changed an IC to one that was readily available, added a capacitor or two and called it the 2.23.
    So here is what i have. Is there any big ugly errors that are going to fry my car battery?
    Any thing else i should consider?
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    Oct 1999
    N Ireland
    Post
    Hi
    I don't see anything wrong with what you've done. It should work fine. :-)
    Feb 2000
    hoppers crossing, victoria, australia
    Post
    the 7812k is only rated at 1.5amps http://www.microsemi.com/corporate/c...p?PARTID=43969
    thats not enough imo
    cheers pcman
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Dustin Haug
    Guest
    Post
    Yep the 7812 isn't going to cut it for most systems. You'd be better off using a switching regulator for the 12V. You'll more current out and it'll be much more efficient.
    Feb 2000
    Post
    yeah
    or use 3 or 4 of em and run each thing of a sep 12v reg
    cheers
    pcman
    May 2000
    NZ
    Talking
    The only thing wrong with the design is you will have to have the car running to give you 12V correctly.
    Think about using the LM2577T for the 12V and run the input from the 5V supply.
    This way the car can be off and you can still use the pc.
    more info on website
    cheers
    andi
    Andi
    http://www.andicorp.com
    Setup: P233MMX, 32MBRAM, 8.4GB HD, CUSTOM DC2DC, 40x2 LCD.
    Jul 2000
    Ottawa, Canada
    Post
    So would one LM2577 (3amps) be about enough for a basic system (MoBo, HD and character LCD?)
    Apr 2001
    Portland OR
    Post
    Originally posted by Machs_FueL:
    <STRONG>So would one LM2577 (3amps) be about enough for a basic system (MoBo, HD and character LCD?)</STRONG>
    The 2577 will only give you around less than one amp of output current for a given design. It says 3 amps, but that is the current it can sink through the inductor.
    On my box I am using a laptop power supply. 1 amp from 12 volts will run a low power mobo, and hard drive. (not including the 5 volt line)
    There are other linear regulators other than the 7812 that can do 5 amps. You still need to satisfy the input voltage of 1 volt higher than the desired output.
    Jeff_
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Apr 2001
    Portland OR
    Post
    Originally posted by andicorp:
    <STRONG>
    andi</STRONG>
    Wouldn't it make more sense to take the input to the LM2577 from the 8-16 volt input rather than from the output of the 5 volt MAX787 ?
    How much current can you get out of the 2577 anyway?
    Jeff_
    www.mpegbox.com
    Jul 2000
    Ottawa, Canada
    Post
    Ya i was thinking having the LM2577 right off the Vin, because that would give the PSU the ability to operate with out the car on
    hit reload and the diagram should change showing what i was thinking
