Results 1 to 2 of 2
Thread: mobo grounding
    FLAC ppgt94's Avatar
    May 2001
    USA
    Post mobo grounding
    Real quick question... Can I just use a ring tongue connector connected to a screw on the mobo wired to the chassis of the car for a ground? The computer runs fine with the mobo not even grounded right now...that is other than the psu going into a grounded inverter. Is that enough or should I do the above? I haven't routed sound to the stereo yet and am wondering if I should do this to prevent some type of noise?
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    If you get noise, ground it. If you don't have any noise when you hook it up, don't worry about it
