Results 1 to 2 of 2
Thread: Questions on Sproggy's mk2 power supply
    Oct 1999
    Yukon, ok , USA
    Question Questions on Sproggy's mk2 power supply
    Here they go.
    What are the characteristics of the MBR745
    Zener diode? (volts, current).
    What are the current ratings on the 47uH and 20uH coils?
    Also what does the 20uH coil do?
    All of these questions reference half of the 5volt section.
    What I am trying to do is find equivalent parts for replacement.
    Apr 2001
    Portland OR
    Post
    45 volts of stand off (reverse bias), 7.5 amps, 0.5 volts forward voltage. Search on www.digikey.com for a data sheet or to order. Costs about 65 cents.
    Chances are they are rated for more than 5 amps seeing is that is the output current.
    14 to 16 gauge wire should do the trick. You can wind your own if you wanted.
    It isolates the feed back loops of the regulators. That way one regulator does not try to compensate for the other regulator.
    If you got the adjustable version, you could set the output voltage to 5.5 volts and then use another of the 0.65 cent MBR745 diodes in its place. You might have to tweak it to get it to work symetrically.
    GO to www.national.com and go to the analog power supply section. They have similar switches.
    Jeff_
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
