Sorry, but that is totally incorrect. You must limit the current flowing through LEDs. Manufacturers generally have a maximum current(typ. 15-40mA) allowable in the LEDs datasheet. LEDs (light emitting diodes) are as the name suggests diodes. If you connect them without a series resistor they will try to pass as much current as is available and be destroyed allmost instantly(at 12V). If you want several levels of brightness then run the with two different series resistors. Also it is fine to connect multiple series of 5 LEDs across 12V in parallel as long as each series has its own current limiting resistor. I'll give you an example of multiple chains of series LEDs being run at multiple brightness levels using two resistors per chain of 5 to change brightness levels. In the example the LEDs will be normally off, dull when the headlighs are on and bright when the breaks are on.you can't "give" the leds more current. they will pull the most current that they need when you have no resistors attached. now my knowledge of electronics is limited, and i dont know if this is sounding right at all...but you would have to set up some kind of switch so that when you brake the leds switch to a power source without a resistor, enabling them to be their full brightness. you could accomplish this with a relay of some type.
To make the dull current 10 mA use the formula from my previous post.
R= (Vin - V(total)forward) / Current
R= (12-(5*2.0)) / 0.01
R= (12-10) / 0.01
R= 2 / 0.01
R= 200 Ohms
and a brignt current of 20 mA.
R= (12-(5*2.0)) / 0.02
R= (12-10) / 0.02
R= 2 / 0.02
R= 100 Ohms
So for half bright we need 200 Ohms and for full we need 100 Ohms per series of 5 LEDs.
I'll edit this post and add a circuit diagram as soon as I have drawn it in crappy paint. This will show more clearly how to wire this baby up.
LinkBack URL
About LinkBacks
