Results 1 to 8 of 8
Thread: Extra power options?
    Nov 2000
    Question Extra power options?
    I'm trying to get some extra power in my car to give me the freedom to let my PC system run for a short while when the car is off. So far, I can only find two options; a second battery or a UPS.
    Unfortunatly, I don't think I have a place to mount a second battery (95 Camero) and a UPS is very ineffecient. Any ideas?
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    You don't need any extra power for "a short while". Check out the thread on power consumption here, people are reporting 2.5 Amps on average. At that rate, you've got at least a few hours before you drain your battery.
    If you just want something to shut off power automatically after some delay, do a search here on "shutdown controller" or "auto-off" or "delay circuit". Or just use my circuit.
    Custom Linux system on an '89 VW GTI 16V Edition One
    Jogdial volume control, Sony joystick, IR remote...
    Used to be the fastest Linux on the road, until all these NOS types came along...
    Oct 2000
    Vancouver, Canada
    Post
    And a mighty fine circuit it is.
    95 Honda Civic DX Coupe - In Progress
    mp3civic site
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    I have a Honda Civic w/ stock battery and alternator, my system draws 6 amps.
    I have never run my battery down.
    I would recomend http://www.dschmidt.com/autooff.html
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Nov 2000
    Post
    I do use a Dschmit auto-off board right now to shut down my PC when my car stops, but that's damned annoying when all I need to do is get gass or something.
    I have tried running the PC off the battery for a little extra time, and when I try to start the car back up, my inverter give me a low battery alarm and needs a little time before it will give power to my PC.
    Feb 2001
    louisville,ky,usa
    Post
    I worried about that when i had an inverter.. with the Arise DC/DC PSU, it has a varable input of 8 - 16 volts.. So the drop in voltage is not a big deal to my box unless you have to crank the engine for a while.
    I cheat, I own an empeg.
    Meskimen's Law: There's never time to do it right, but there's always time to do it over.
    http://civic.mp3car.com
    Dec 2000
    Smyrna, Ga, USA
    Post
    I have not gotten my dschmitt box yet, (on order though) when I get it, i plan to add a capacitor w/ diode onto the accessory line, this will allow me to change the wait time to (my goal) 12 minutes or so.
    Gizmo-
    Jan 2001
    Adelaide, SA, Australia
    Post
    I recoment oms circuit, so simple yet affective. i built mine for about $au5 high finances indeed! i get about 8 mins running time after i have turned off the key.
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
