Results 1 to 10 of 18
Thread: P1900 as power supply
    Registered User EmoRebellion's Avatar
    Oct 2005
    Palmdale, CA
    Hey guys. So, I ****ed up and didnt research fully before i bought. I now have a CarNetix P1900 that i would like to use as my power supply for my carpc. I have dont a lot of searching, and havent really found a deffinitive answer. Can I use this to power my computer? What components do i need? I know i need some form of an ATX psu adaptor. Any links would be great. Thanks.
    I have an ECS P6iWP-FE mobo, in a micro ATX case.
    BTW, please save me the "BUY AN OPUS 150W D00D!!!11!!1!!ONE!!" speech.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well, most of us learned by making a mistake.
    What you have there is a an 18 volt 140 watt power regulation device. IF your PSU can take that voltage in and convert it, all is not lost.
    However, IF your PSU requires 12 volts, you're in deep kim-chee.
    Want to:
    Oct 2005
    Palmdale, CA
    this is the power supply i have in there: http://global.aopen.com.tw/products/...SP145-60SA.htm
    Elsewhere
    OK. The Carnetix unit you purchased doesn't have the outputs to a motherboard, HDDs, etc. It only provides regulated power to a 'power brick' type of power supply that some small form-factor PCs employ.
    The power supply you linked to above is a standard ATX power supply. You need something that will either allow you to provide power to the motherboard and devices (Opus, DSATX, KeyPower) or provide 110vAC to your ATX power supply (inverter).
    How about the Wiki?
    Oct 2005
    Palmdale, CA
    I know that. Isnt there some sort of adaptor that takes all those damn wires and turns them into an atx psu?
    Aug 2004
    No. That 120V power supply nor the carnetix will do you any good.
    Seems like you're looking for a 12V 140-150W ATX power supply. Look at the Opus products, just make sure you do your research first. Figure out how many watts you need, figure out which one you need, research it to make sure it's a good performer, and if needed phone your supplier to make sure.
    The carnetix power supply you bought is for the Xenarc PC's, which are Sumicom PCs, and for Mac Mini's, and random laptops and boards that take 19V and have a built-in atx-style power supply.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by EmoRebellion
    yes.
    Quote Originally Posted by Vinister
    Wrong.
    You need to buy one of the ATX power supply units that run off 14-20V or 18-28V whatever they are.
    just off to look in the shop....
    ..none at mp3car but these are at linITX:
    150W 14-20V (limited to P1900 140W obviously): http://linitx.com/product_info.php?c...roducts_id=428
    125W 14-19V (you can use the carnetix secondary output to use the remaining 15W at 5V or 12V): http://linitx.com/product_info.php?c...roducts_id=283
    120W 18-28V (again use the P1900 secondary output to use the remaining 20W): http://linitx.com/product_info.php?c...roducts_id=771
    Elsewhere
    We're telling you plainly that there is no adapter. We're not full of bull**** or out to screw with your mind. There truly is no such adapter. We're sorry that your miracle product does not exist, but you do need to accept the fact that you purchased a product that is of no use to you.
    Deal with it, resell the Carnetix and move the **** on.
    How about the Wiki?
    Oct 2005
    Palmdale, CA
    dude, ****in chill. I NEVER* said you were full of bull****. The reason i made this thread is because i have finding mixed answers, and still am.
    Why wont those products that Scouse listed work?
    EDIT: Forgot that word*
    Mar 2004
    Bristol
    they wil work. listen to me. i am the master.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. REVIEW::220 Watt DC-DC Power Supply: DSATX
    By seabeggar69 in forum Power Supplies
    Last Post: 03-20-2006, 05:53 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
