Results 1 to 10 of 11
Thread: Another inverter question...for electronics gurus
    moahdib's Avatar
    Jul 2000
    Post Another inverter question...for electronics gurus
    Since I am not that great in electronics I gotta question:
    I have a 300W Inverter and my computer power supply is 150W. Does my inverter need to be wired with thick wires just bc its a 300W? I know the computer will never consume more than 150W...
    I am thinking of redoing the wiring bc the invverter dies sometimes... using 8 gauge wire running 12feet, fused with 30A and a switch to cut the power on and off ( 12V@20A rated rocker type switch) is this a good idea??
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Apr 2001
    Here, There, Everywhere
    Post
    Originally posted by moahdib:
    <STRONG>Since I am not that great in electronics I gotta question:
    I am thinking of redoing the wiring bc the invverter dies sometimes... using 8 gauge wire running 12feet, fused with 30A and a switch to cut the power on and off ( 12V@20A rated rocker type switch) is this a good idea??</STRONG>
    I run 15A auto cable (about 3mm think in diameter - not including insulation) to the inverter. It is a 120W Jaycar model (aust. company) and it is running a 300W ATX PSU.
    The computer is a Duron 800MHz, ASUS MB. 8 Gauge is a definate overkill.... but if you arent running the inverter directly to the battery at the moment (using the cig lighter,etc) I would be trying that first.
    Project - GAME OVER :(
    moahdib's Avatar
    Jul 2000
    Post
    Hmmm but im running the 8 gauge all the way to the trunk ( about 10 feet or so ). I was also thinking about powering up my bazooka subwoofer ( 200W ) by adding a distribution block.
    My TL CarPC ver2
    Mar 2001
    Phoenix
    Post
    Distribution block sounds good, but I would use a relay on the inverter that way you wont have 8ga wire going under your dash to some switch, you can just run 18ga wire from the switch to the relay and let it handle the load. And 8ga should be fine.
    Steve
    Mar 2001
    Cincinnati, Ohio
    Post
    I will tell you how to do this, but you sacrafice the warranty on your inverter.
    Most inverters will not come back on after having the electric cut off to them by using a relay, so..
    1. Unscrew the inverters front panel and look for the wires running to the switch.
    2. Cut the wires, and use 2 wires of similar gauge, attach them to the old switch wires, use solder and Wire nuts, and run it out the front panel (Be very careful, there are big capacitors in there)
    3. By a small toggle switch and mount it in the dash of you car, run the wires to it.
    TADA
    And, use atleast 8-gauge. Come on people, I mean the wire is cheap! use it! Hell, I used 6 gauge, but I have a 600 watt inverter.
    You can never have enough, but you can have to little.
    And in awnser to your question, no, the inverter will only draw as much power as it has to, but initially, when you turn it on, it draws even more than 300 watts to charge its capacitor.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Mar 2001
    Phoenix
    Post
    Theres only one problem with that, some inverters (like mine) only cut the output off (110vac) and leave the inverter in idle mode which draws about 2/10's of an amp. Now I know this doesn't sound like much, but over night it could drain your battery so it wont start (I know it happend to me and yes my battery was in great shape!)
    Steve
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Originally posted by lstrunk:
    <STRONG>2. Cut the wires, and use 2 wires of similar gauge, attach them to the old switch wires, use solder and Wire nuts, and run it out the front panel (Be very careful, there are big capacitors in there)
    </STRONG>
    Huh? Large capacitors? So what. They're charged to 12V.
    Uh, 14AWG is significantly cheaper than 8AWG, and much easier to run.
    For most people, running wire this thick would be very annoying. Thinner guages are cheaper, and easier to install. Also, the connectors at each end are cheaper, and it is much easier to solder thinner wire.
    Jul 2000
    Australia
    Post
    Wouldn't there be capacitors to filter the output of the invertor (i.e. charged to mains voltage)? Or do they just rely on the input being filtered to give a good output signal?
    Apr 2001
    Portland OR
    Post
    Originally posted by Aaron Cake:
    [QB]Huh? Large capacitors? So what. They're charged to 12V.QB]
    I think he means the ones on the internal high voltage DC bus. They could be charged to 200v or something..
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Mar 2001
    Cincinnati, Ohio
    Post
    Even 1 volt could kill you with enough ampreage. It doesn't sound like you really should be messing with anything electric.
    Whats the big difference, you still have to pull up your carpet, and everything?
    And if you can't afford the 10 cents extra a foot for good wire, you shouldn't be doing this project.
    What are you soldering it for?
    On the back of my inverter atleast, is just two boxes you stick the wires in, and screw clamps down on them.
