Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Power rating of T6
    Jul 2001
    Post Power rating of T6
    Isn't the coilcraft T6 transformer only rated at 630ma??
    so therefore on Sproggys circuit, you can't draw 1.3amps on the +12volts and 200ma on the -12v and 5v combined?? or, did I miss something again..
    [ 10-30-2001: Message edited by: SkinnyBoy ]
    Aug 1999
    Washington D.C.
    Post
    EDIT: Thanks for changing the subject
    [ 10-30-2001: Message edited by: ZipLock ]
    Jul 2001
    Post
    why is everyone so hard on skinnyboy
    Sep 2001
    Post
    I don't know... I've seen him make some very helpful posts. Of course I've seen some lame ones too, but it doesn't bother me. He's helped me more than he has hurt me.
    Anyway. I'm not sure about the rating of the T6 (the datasheet didn't mention anything but temperature rating and dimensions), but I did notice it getting pretty damn hot when I was running my system. It says it can handle -40c to +85c. I hope it won't blow
    Where did you find the electrical specs on this?
    -Miles
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
    Jul 2001
    Post
    The specs I have for T6 are actually for a different transformer made by a different company, but all the specifications are the same.
    The companies website is www.rencousa.com
    the part number is RL-5533
    BTW, you can also get free samples from them if coilcraft won't send you one...
    Jul 2000
    Israel
    Post
    5v has nothing to do with T6 on Sprossy's supply.If you use more current on -12v,you will get less on 12v.
    Enjoint life!
    Jul 2001
    Post
    I meant -5volts, and isn't the transformer only rated at 630ma???
    So, as I said before, how can you draw 1.3amps???
    Oct 1999
    N Ireland
    Lightbulb
    1.3A is what the National design program produced and I had no evidence to disprove it. Coilcraft did not display the current rating of their transformer.
    Very little current is used by the -12V and -5V. With the flyback design, what is not used on the -12V winding can be used by the 12V winding (limit is core saturation). If no current is use by -12V winding, 1.26A (0.63x2)is available on the 12V winding. The windings have low enough resistance to not expell much power (0.19W @ 1.3A).
    Sproggy
    Jul 2001
    Post
    Hmmm...
    okay then....
    FLAC Mastero's Avatar
    Aug 2001
    India
    Post
    hey sproggy buddy then how come im getting 3.3amps on the 12vdc rail ...
    and im getting 5.3 and 5.3 on the 5 and 3.3 vdc rails
    so i guess the meter is working fine....??
    Then how come 3.3amps on the +12vdc rail all i have changed in your design is the SA28A diode to some equivalant one... ???
    Mastero
