i've got a
and a yellow top optima
works spot on
i dont have any pictures yet as my wires are in a big ball of mess still right now.. i'll tidy it up this weekend and post though.
wiring the stinger was a snap though, run one wire from the main battery to it, one wire from it to new battery, a small ground and a small remote turn on wire and i was all set. i used 4 gauge for the power wires and fused it to 80 amps. i DID still manage to run my main battery low one day after several hours of leaving the car on but that was probably because i wired the remote to a NON-ignition wire, meaning the stinger's relay was triggered even though the car wasnt running, only in the first key position.
Live mp3Car Facebook Chat
i've got a
works spot on
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
this is my $2 setup, fuses near car, pc batteries and PSU not shown. the PC battery is disconnected from car battery when you turn car off (ACC off), and during engine cranking (some cars may not disconnect during cranking).
Code:+------+ ACC ----| coil |----- GND 85 +------+ 86 +------+ Car Battery ----+ +-----------------+---| PSU | 30 \ 87 | +------+ \ | PC battery
Check this thread Battery Recommendations?
The old setup http://flickr.com/photos/ilyassx
The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
Jetway J7F2WE VIA C7 1.5 GHz
512 DDRII 533
3.5" SATA2 H.D.D 200GB
M1-ATX
ELM327MS OBDII
Creative Audigy 4
PROGRESS:[########-]90%
those are the terminals on the standard 5 pin relay... look at one & you'll see![]()
ouch! ...thanks, I'm really a noob![]()
The purpose of the diode is to keep the secondary battery from discharging into your cars battery or accessories. Iv been doing some research on powering my PC this way and I only have two unanswered questions left;
one: Will these work?
http://www.allelectronics.com/cgi-bi...gi?item=GC-217
http://www.allelectronics.com/cgi-bi...?item=1N1190AR
two: Will this setup help regulate the power (i.e. keep it around 12v both during crank and normal operation)?
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Engine died)
Work Log v4.5 --> 05 Toyota Tundra DC SR5
