Results 1 to 6 of 6
Thread: opus 150watt shuts down and starts up computer randomly while driving
    Poe
    Poe is offline
    Oct 2005
    i have a 150watt opus psu. computer specs are...
    PIII 800mhz
    256mb ram
    onboard video
    usb sound
    2.5" laptop hd
    the opus will start up the computer when the car starts and run it just fine. after a few minutes... it will make the computer hibernate. then after a few more min, the computer will boot up again. the timing doesn't seem to be random from what i can tell. the computer always hibernates after 1-2 min after ignition starts... then will boot again after about 2 minutes. after it boots the 2nd time... it will stay on for the duration of the car ride.. until i turn off the ignition. does this seem to be an issue with the ignition input wire? it didn't do this before. for the first 2 weeks or so it worked fine. this problem just started.
    btw, i'm using my accessory powered cigarette lighter as ignition input for the opus. this worked great before... i have no idea why it's randomly shutting down and starting up the computer now.
    Low Bitrate pastypyro's Avatar
    Nov 2004
    Austin, TX
    It might be the low battery feature in the OPUS. I'm not completely sure, but it's a possibility. How old is your car battery?
    Xenarc 7" USB Touch LCD / 3.06 GHz P4 / 512MB DDR / 250GB 7200RPM 16MB HD /
    DS-ATX 220W / Centrafuse / GPS / XM / 802.11g: 6db / RF Keyboard
    Oct 2005
    It could also be your alternator not charging enough.
    A new battery would be my first option though.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    or a loose wire... a bit of reading woulf have told you all of these things
    TruckinMP3
    Read the FAQ!
    Poe
    Poe is offline
    Oct 2005
    i think there's something loose inside the opus. all the connections outside are fine... and if i wiggle the power plug on the opus (with the ignition on) the computer will turn on. do you think opus will take care of this problem? the unit is almost brand new... been using it for 2-3 weeks.
    Jun 2002
    Colorado
    Contact them and ask
    TruckinMP3
    Read the FAQ!
