Power Supply and Inverter question
I just won an auction for a Advantech PCM-5862 SBC, and until I have the $$ to buy a DC-DC power supply I have an old 150W AT power supply that I am going to power it with. I have a 140W inverter already. Here's my question: will I be able to (safely) use the 150W power supply with a 140W inverter? I will not be comming anywhere near the 150W limit of the power supply - I'll only be powering the SBC (requires max. 7A @ 5V), a Matrix Orbiytal LCD (12V wide voltage version), a hard drive and a couple of fans. My current car PC uses a custom Compaq 110W power supply which I was using with the inverter and I never had any problems. Any suggestions would be apprecaited!
Thanks,
Mike.
Retired Admin
Search.
I have been searching, and the post I have read seem to indicate that it is OK to use a power supply rated higher than the inverter since the power supply will only draw as much power as it needs. Also, the inverter can handle up to 250W peak, so even if more than 140W is needed at startup for a second or two, it should still work. I just wanted to run this by everyone to make sure I wasn't missing anything.
I had another thought as well - since the SBC only requires 5V, I could always switch to a notebook hard drive and then I would not require 12V at all - the entire system would run off 5V. Is there a power supply that works off DC that could do this? I was thinking of using a universal notebook DC supply like the one from Targus to supply 5V since they will work up to 70W (more than enough for an SBC, notebook hard drive and character LCD). Any thoughts on this?
Thanks again,
Mike.
Thanks Meatballman. Maybe I should just cough up the money for the Arise DC-DC. I can't find any distributors who sell the Arise power supplies. Did you order yours directly from Arise?
Thanks,
Mike.
mtmsol , the short answer is yes. Im running my Duron 800 and a 6.4GB HDD with a 300W ATX PS and a 140W inverter, works fine.....
the 300W is the max the PS can support, it will not suck 300W all the time only if it was loaded up running enough hardware.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
