Results 1 to 7 of 7
Thread: Arise
    Mar 2001
    Cincinnati, Ohio
    Question Arise
    I am looking into buying a PS DC-DC from arise.
    They one they suggested (mpd-7061S or something) has AT connectors, but doesn't seem to have a -5V only +5, +12 and -12 are listed and there amperage given, but no -5!
    And, those mini Powersupplys, do they fit in a standard AT PS space? or do I put them outside the case?
    cause the one I am looking into is only 75$, and the cheapest Case looking one is 150$.
    And, the one I talked about above, does anyone have it, what was your experience like, and how hard was it to install?
    Does AT connectors come built on it?
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    first off, if ur MB is AT style or a combination of ATX/AT then get the ARISE ace-865v. For more information if u really think this wont power up ur box, then go take a good look at my setup. I think that will convince you to get it.
    abcd-1
    Apr 2001
    Portland OR
    Post
    Originally posted by Charles Enwesi:
    <STRONG>if u really think this wont power up ur box, then go take a good look at my setup.</STRONG>
    Most of your links in your sig don't work, is this just network problems?
    Jeff_
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Aug 1999
    Smile
    ops....you are right. I fogot to setup this new ftp server to give access to those dir. The main one should work though.
    Thanks for letting me know.
    abcd-1
    Jan 2000
    Post
    Write this day down in history, look who just admitted he made a mistake, holy ****!!!! Just kidding cenwesi, keep on coding buddy
    topperge
    Mar 2001
    Cincinnati, Ohio
    Post
    Thanks Cenwesi,
    I was looking into that one.
    Stupid Question though,
    what happens when your rev the engine or something, and it goes above 16volts, or after you start the engine and is surges to 300volts or something, will these not burn up or anything?
    And, wouldn't I be better with the MPD-whatever one since it goes from 10 to 30 volts? and has higher amperage,
    but, I am only powering a p120 with a 1 gig HD, and a CDrom, and possibly a LCD display.
    Will the one you suggested be enough?
    Thanks man,
    All, BTW, would anyone be interested in buying a Portawatz 600?
    Since I am getting this to get rid of it.
    It no longer has a working switch, since I ran it to my dash, so its just two wires sticking out the front the have to have a small toggle switch put on them.
    I would want 70$ since they are worth 149$ (I got mine on discount though since it was the last in stock.)
    Just askin, cause my dad said he might want it to power a small ceramic heater for his truck, cause it has sucky heat in the winter.
    Jun 2000
    Salt Lake City, UT, USA
    Post
    Originally posted by lstrunk:
    <STRONG>Stupid Question though,
    </STRONG>
    I just put a 5A fuse on the posetive cable going to my DC-DC psu. I figure it was rated at 7 amps max so the only thing that can go out is the fuse.
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
