Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Burned m1-atx, is this the voltage regulator?
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    First, the pic:
    Not sure how this happened, I'm pretty sure I broke it. I'm really new to soldering and I'm not comfortable replacing this part myself. Does mp3car.com or minibox do repairs? can I get it repaired for less than the cost of a new one or should I just shell out for a new one?
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    call the manufacturer, tell them what happened...
    They may replace or fix it for you.
    TruckinMP3
    Read the FAQ!
    Nov 2003
    Northern Arizona
    Quote Originally Posted by TruckinMP3
    Really? Even though I did it? Do I call mp3car.com (where I bought it) or mini-box?
    My worklog.
    Jun 2002
    Colorado
    Try Minibox.
    TruckinMP3
    Read the FAQ!
    Aug 1999
    Washington D.C.
    That chip blows when the 12V rail is overloaded or shorted out.
    Nov 2003
    Northern Arizona
    Quote Originally Posted by Zip-Lock
    I'm sure this is my fault. So I was connecting a relay, controlling it from the 12V (molex connector from the m1-atx). I've got a bosch type relay and one of those relay sockets, which provides a nice harness with leads for each terminal on the relay. I wired the socket, hooked up the control wires to the m1-atx 12v rail. I was going to test the amps pulled by the across the controll lines to make sure it wasn't much. I'm not quite sure what I did wrong, but between the time the PC started up and me getting back to the hatch to check, I saw smoke. Somehow I was shorting the control circuit which overloaded the 12V rail.
    I contacted mini-box. Maybe they can repair it for less than full cost? If I could pick one up locally, I'd be tempted to do that. I had a bunch of time set aside for getting GPS working this weekend and now I'm at a standstill.
    My worklog.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Buy a new one, fix and sell the old one.
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    As long as you know how not to repeat the burnout...
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Aug 1999
    Washington D.C.
    The reason this happened is the M1-ATX doesn’t have overload protection on the 12v rail. The next version, the M2-ATX, will have overload protection on the 12v rail.
    Nov 2003
    Northern Arizona
    Ahh, so it has a fuse on the input side to protect against total draw, but nothing for the individual rails.
    My worklog.
  1. m1 atx
    By corsab in forum Power Supplies
    Last Post: 08-21-2005, 09:03 PM
  2. Voltage Regulator Constant Heat
    By phita23 in forum General Hardware Discussion
    Last Post: 02-21-2005, 01:18 AM
  3. Mastero MK-4 ATX PSU Semi kit for SALE
    By Mastero in forum Classified Archive
    Last Post: 06-10-2004, 02:42 PM
  4. Idea for a cheap 12 voltage regulator perhaps...
    By adamis in forum General Hardware Discussion
    Last Post: 09-11-2003, 08:31 PM
  5. Linear Regulator & Supply voltage.
    By vickumar in forum Power Supplies
    Last Post: 05-30-2002, 09:07 AM
