Results 1 to 10 of 12
Thread: M1 Atx Psu
    Oct 2005
    M1 Atx Psu
    What sort of power will this run, How many USB devices can you use ?
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    C'mon now, do your own homework. Go to the mp3car.com store, find the m1-atx product listing, click on the "specifications" link. That will tell you how many amps at various voltages the m1-atx can supply. Then you figure out how many amps at what voltage your USB devices take then you're done.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    Oct 2005
    I can never work these damn thing out.
    Ok Spec and bits.
    Sp13000
    512 Mb
    40gb 2.5" Hdd
    Usb Network Ad
    Usb Bluetooth
    Usb Mini Speakers
    Usb Touchscreen
    Usb mini key/mouse
    Usb GPS reciver
    and Thats it.
    will it be Ok?
    Nov 2003
    Northern Arizona
    Hmm, you didn't even try? Did you go to the store and download the specs?
    Well, I thought about bashing you some more, but I suppose I'll just help out.
    I googled "power supply calculator" that led me to some Intel/AMD type calculators. I then googled "power supply calculator epia" and found this:
    http://resources.mini-box.com/online...simulator.html
    You can't configure your exact system, but it does get close. I added 6 USB devices, and it looks like that will work. The M1-ATX has a 10a max on the 5V rail (which powered USB, I think). You'll need a USB hub, not sure if that sucks more power too. Also, if you're powering the screen that'll draw from the 12V rail not the USB port. So, it looks like this will work. Don't come crying to me if I'm wrong. This was a 15 second estimate.
    My worklog.
    Apr 2002
    Houston, TX
    Yeah and remember this is the guy who just blew up his M1 ATX
    Burned m1-atx, is this the voltage regulator?
    So he knows what not to do......
    I just couldn't resist kbyrd
    Nov 2003
    Northern Arizona
    Quote Originally Posted by dug1967
    Thanks ;-)
    For those who are curious, I overloaded the 12V rail, but not because I was intentionally drawing to much. I reversed the + and the - wires connecting to a diode and it becomes a short circuit.
    My worklog.
    Oct 2005
    Looks like i will be ok,
    I will use a hub for the non essientail items, like keyboard,mouse which are just for back up.
    cheers Kbyrd
    Nov 2003
    Northern Arizona
    Quote Originally Posted by scooby8272
    The only reason I said "you need a hub" is that there aren't that many USB ports on the mobo. If you use a non-powered hub, the devices on the hub still draw from the mobo which draws from the PSU. If you use a powered hub, well now you have to power the hub somehow, usually by splicing a wire from the PSU or buying a "point of load regulator" (a simpler DC-DC power supply)
    My worklog.
    Oct 2005
    I have used the usb risers on the mainboard giving me 4 more usb ports, i have 6 in total now
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    The sp1300 has 6 usb ports if I remember rightly.. 2 on the back and two headers on board :-)
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  3. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 12:08 AM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
