Results 1 to 3 of 3
Thread: ups and power inverter shutdown controler
    Oct 2005
    surrey bc
    any schematics to hook them up together that people have already done so i dont have to trubleshoot the situation
    Oct 2005
    surrey bc
    i need to have both i think
    ok i took a laptop that the hard drive and cdrom circits to conect them to the mother board were broken so i soldered a 40 pin ide cable in its place now to run my hd / cd rom i need an atx power supply and the laptop battery was gone so i have to plug it in to 120 ac.
    so to power them i bought an inverter works great but i wanted it to shut down with the ign .
    so to turn it on i used a momentary on relay schematic i found and soldered it to the power switch .
    now to turn it off i bought a ups to use the parts but it works fine so i am going to try and use it so my idea is to go from the bat - inverter and take the inverters 120ac - ups then from the ups to the laptop and power supply it works i tryed but it beeps that i can fix but here is the question can i take the 12 volt from the atx power supply to run the laptop
    attached ****ty *** pic
    i have hooked a bigger battery to the ups it lasts a wial but i am going to hook up a relay so that it cuts the power to the atx power supply so that its not drawing any power make sence i hope so ( or i will hook a relay timer up to the switch on the ups to turn it off after 5 mins )
    Oct 2005
    surrey bc
    this is a **** idea
    ok i scraped that and i hooked the laptop up to the atx 12 volt works now i need a shut down controller is there any that i can build i have looked at a lot and i cant figure out the one from car domain all i need now is to shut off an atx with a little time to spare for shutdown i have 555 timers i have pnp , npn transitors i have relays i need help please i can biuld it i just need some direction some of the schematics i have found aren exlanded well enough and i am not a newbie i have been on this site for about 3 years just never posted any thing please help and i will help you with any thing i can i will be posting all my pic soon thank in advance
  1. Found someting interesting on E-Bay!!!
    By outragis in forum Classified Archive
    Last Post: 01-23-2006, 09:38 AM
  2. Inverter powered UPS for CarPC?
    By AWDNUT in forum Power Supplies
    Last Post: 09-14-2005, 12:30 AM
  3. HELP on Using Inverter and UPS to power carpc
    By davidbudi in forum Power Supplies
    Last Post: 04-27-2005, 11:36 AM
  4. 300watt inverter, 700va ups and a 90watt powersupply?
    By MikeXP in forum Power Supplies
    Last Post: 08-22-2004, 07:29 AM
  5. UPS power backup as inverter?
    By CA 3000GT in forum Power Supplies
    Last Post: 02-13-2003, 02:52 PM
