Results 1 to 6 of 6
Thread: relay, inverter, fuse problems
    Oct 1999
    London England
    Post relay, inverter, fuse problems
    I currently use an inverter to power my car mp3 player. In my old car i had the inverter mounted under the drivers seat and ran a 120v power lead to the computer in the boot (switched on manually). This worked fine. I now have a new car and decided to mount the inverter in the boot with the computer. I purchased a relay with a 30amp fuse on it. I installed a switch that ran off the ACC line to the relay (pin 85) and connected a ground (pin 86) to it also. I connected 10guage power wire from battery (fused at 35amp) to the power input (pin 30) and the other pin 87 to the positive input on the inverter. I connected the negative input on the inverter to chassis. The problem is as soon as the relay is switched on the fuse blows on the relay. Is this because the relay is fused at 30amp while there are 35 amp fuses in the inverter and at the battery connection? The fuse blows when the inverter circuit is connected but before it is switched on at the switch on the inverter. I have not tried higher rated fuses in the relay because i didnt want to risk blowing my inverter. There are no obvious short circuits that i can see. Any help would be appriated as to what i am doing wrong. Cheers
    Oct 2001
    Ontario, Canada
    Post
    Fuses will only blow as soon as you turn something on if there is a short somewhere. Drawing 30 amps from your 12V battery is a LOT of power (360W) for anything, so you MUST have a short... My guess would be that you've certainly got the relay hooked up wrong, what type of relay are you using, and why does it have so many pins? If you hook everything up to the inverter directly, will it blow the other fuse?
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Exclamation
    Sounds like your relay is connected wrong. Do you have a schematic or something demonstrating how you have things hooked up? Fuse ratings really have nothing to do with this.
    Oh, and this topic has been moved to "Power Supplies".
    Low Bitrate Zharvek's Avatar
    Jan 2005
    Newbie patz's Avatar
    May 2005
    Canada
    i got exact prob last week end...
    work great in my house.. but in the car, when i turn on switch.. i blow up few fuses........
    why ?! .. i inverted + and -
    May 2005
    Canada
    btw.. did you put a diode on coil ?
