Results 1 to 10 of 15
Thread: CarPC Wont Boot
    Mar 2005
    UK
    CarPC Wont Boot
    the computer does not even turn on.. when i do it get it on sometimes it posts then crashes.. a red light apears on the motherboard.. its an Abit AA7 i think off hand..
    I need help!!!
    I have got a OPUS In Car 12V DC-DC 150W ATX Enclosed Power Supply
    http://linitx.com/product_info.php?c...roducts_id=344
    The specs of the computer are :
    amd athlon xp 2000+
    512mb DDR Ram + 256mb DDR Ram
    60gig hd IDE
    PCI Sound Card
    128mb agp nvidia geforce 3 ti 200
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    Have you calculated your power requirements on each rail of the PSU? Sounds like problems from over driving your PSU.
    Mar 2005
    UK
    i used a factory 145watt powersupply no trouble at all!
    Aug 2005
    New York
    Power supplies vary. If the stock one has more juice on the 5V rail and that is what is straining on your Opus, it doesn't matter that the OPUS has 5 more watts. The important factor is what your system requires and what the Opus provides on each rail.
    Mar 2005
    UK
    will i be better off getting a 200watt psu ?
    Mar 2005
    UK
    well i mean all fans turn on etc.. then no display..
    Aug 2005
    New York
    If your problem is not because of power issues, than no you won't. I can only make assumptions, it may not be that you are drawing too much power. Your PSU could be bad, or your wiring is not correct. There are a lot of possibilities, but you can narrow them down if you calculate your power requirements.
    Mar 2005
    UK
    i just did a wattage calulator.. it came to 165watt
    Aug 2005
    New York
    Again, wattage is not the problem obviously. You need to look up the requirements of each of your components and add up the total requirements on the 3.3V, 5V, and 12V. Then look up the output of the Opus and see if you are over the limits. You may be within limits, which will rule that problem out. If you have the money to waste and don't want to deal with the problem properly, just buy another PSU. Problem with that is it may be a wiring issue and a new PSU won't do anything for you.
    Mar 2005
    UK
    i dont understand this but when i take the ground off its still runs.. i can't see where its grounded.. unless its grounding through the usb port to the touchscreen diplay..
  1. Replies: 10
    Last Post: 04-17-2006, 06:23 PM
  2. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 07:03 PM
  3. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  4. CarPC wont boot!
    By FRP in forum General Hardware Discussion
    Last Post: 06-26-2005, 11:07 PM
  5. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 04:21 PM
