Results 1 to 7 of 7
Thread: optima yellowtop overcharging
    Nov 2004
    New York
    Hey Guys..
    Well, my system was running problem free off my secondary optima yellowtop, connected to my starter optima batteryt with a stinger voltage regulator for about 6 months, and yesterday I smell sulfur while driving. I learned that this mostly likely was because the battery was being overcharged. What are some possiblilites for this to happen? The secondaty battery was tested in the past, and it seems it was a constant 14.5 or so. Recently I did have some blown fuses in between the two batterys, but I believe it was caused by my AC/DC inverter alway pulling power from the battery when the car was off. Also, my secondary battery (located under the rear seat) was installed on it's side. Could this be part of the problem? I know the yellowtop can be installed in almost any position, but now I'm not sure if it was ok. Finally, if the battery was being overcharge (for whatever reason) is the battery now shot? How can I tell if I resolve these problem if it will be safe to use it again? Thank you guys in advance for all you input!!!
    Via epia M10000
    12.1" VGA touchscreen
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    Geforce 5500 Videocard
    Audigy NX USB sound card
    Wireless Keyboard & mouse
    Panasonic slim line -slot load
    w/ usb adapter
    IRMAN
    Nov 2004
    New York
    Oh..I also forgot to mention that when the fuse blew, the secondary battey drew completely dead. So I just changed the fuse, and the secondary battery began charging via the alternator. Mabey this had something to do with the sulfur smell also. Can I charge up the secondary battery once it's fully dead with the alternator, or does it need to be jumped to a full charge first? Thank you!
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    do you have a battery isolator in between the 2 batteries?
    Nov 2004
    New York
    Yes..I'm sorry...it's a Stinger battery isolator
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
    Aug 2004
    Pearland
    in that case im going to go with the battery being dead.. the battery wont overcharge from the alternator...
    I suggest taking your battery in to like a pepboys or something and have them check it out as well as your alternator and everything to make sure its all fine.. they will also be able to tell you more about what could be wrong with the yellowtop...
    oh and yes you can mount the yellowtop anywhich way you want... just not underwater
    Nov 2004
    New York
    Thanx Alot..i Will Do So!!!
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
    Newbie ILLNALI's Avatar
    Jan 2005
    not sure why it was overcharging... but when you smell sulfur from the yellow tops, they are done!!!!
  1. FS: San Diego - Optima YellowTop Battery (51R)
    By Chita79 in forum Classified Archive
    Last Post: 10-30-2006, 10:11 PM
  2. Optima VS Stinger Batteries
    By kozmo in forum Car Audio
    Last Post: 10-23-2005, 06:45 PM
  3. Optima Battery survive crank
    By michaelrj9 in forum Car Audio
    Last Post: 04-13-2005, 06:44 PM
  4. FS: SF Bay Area: Optima Yellow Top
    By VanMan69 in forum Classified Archive
    Last Post: 08-19-2004, 04:17 PM
  5. Optima batteries
    By turbochris in forum Power Supplies
    Last Post: 05-06-2004, 10:54 PM
