Atx Pin #14
Ok Pin #14 is ps on... sproggy seems to disregard this pin as it does not have any connection on the sproggy power supply and I was wondering if this will work ok or if it needs a voltage or not
im assuming that since sproggy doesnt do anything with it then it isnt really needed...
The reason nothing is connected to that pin is because the sproggy supply is designed to turn on when you turn your key to accessory/ignition.
Leave pin 14 empty not needed, go here http://www.skylab.org/~chugga/mpegbox/
look at his pinout mine needed the good power signal before it would come on
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
