Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: How do I change a computer power supplt to give me + - 35v @ about 4amps per rail????
  1. #11
    Jul 2001
    Post
    Also,I think you will need a circuit to prevent click-on-start and shutdown,if you don't want to blow your speakers.
    I've got a circuit that does that, the speaker output isn't switched on untill the amp has been powered for about 5seconds..
    So, no-one knows a site or has a diagram lying around for a switchmode power supply?? okay..
  2. #12
    Apr 2001
    Here, There, Everywhere
    Post
    like Jeff said, for alot of things around us there are not easy answers......
    ....most ppl know this at one point or another, I like to call this "life"....
    (not a grinning smart-arse smile... just a refelction to what I wrote)
    Project - GAME OVER :(
  3. #13
    Jun 2001
    Sebastopol, CA
    Post
    Not my web page, but something to look at
    Go there, look on the bottom of the page. It is linear, unregulated, basic. Adding a regulator to it will increase your overall power supply rejection ratio (PSRR), hence lower 60hz noise. It is not small, but it is simple.
    If you're really bent on using a switching supply, good luck!
    Transformer basics
    Go there, and learn how to wind your own transformer. I recommend a toroidal as they have the least EMI (good for audio).
    If this is for home use, the size difference from a linear regulator vs switching is not really a big deal. It will be quite a bit heavier though.
    Presslab
  4. #14
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    No matter what power supply you build, you will need a transformer. It's that simple. Switching power supplies are much harder to build than linear units, so not many people even bother to design them for hobbiest situations. Best bet would be to buy one on the surplus market.
  5. #15
    Jul 2001
    Post
    Well, okay...
    could someone tell me then, how to modify a computer power supply so that the 12volts is 3 times the voltage??? It can be done right???
  6. #16
    Jan 2000
    Cool
    No, it can't easily be done. If you're going that far, you might as well do it right and design a new supply that is actually meant to provide the higher voltage.
  7. #17
    Jul 2001
    Post
    Fine, I'll keep looking around on the net and in books and see what I can find, thanx for the help..
