*bump*
Doesn't anyone know this ?!?
When the M1-ATX is in the dumb psu mode should it survive engine cranks?
I use a M1-ATX in my setup and have the jumpers set to normal mode. (dumb psu mode) I use a switch on my dashboard to turn it on/off.
Cause mine isn't. I've doublechecked if the power outlet in the boot, My multimeter tells me the voltage dips to 10.2v when I crank the engine.
*bump*
I dont have M1ATX but it should survive the crank. Make sure you have a good connection from the battery to the PSU. There may well be too much resistance in between them.
When the PSU need to operate from 10v due to cranking, it will naturally draw more current to generate the same power output. So make sure you use thick wires.
The M1ATX support guy is here often so he should be able to help you.
Have you tried using the NOT "DUMB" mode?
never used dumb mode, but mine survives cranks w/ no problem...I don't see why dumb mode wouldn't. Do you have an old battery? Perhaps your battery or alternator is bad or going bad and can't provide enough current.
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAMold carPC
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
The battery in my car is fine, at least that's what I should expect from a new battery, I got the car (new) in july.
I'm not using any of the other mode's because the delay's are not good for what I want. I don't want to start/quit the pc everytime i start/quit the engine.
I'll try putting it on a seperate cable running from the battery.
That you should DEFINITELY do. Where do you have it running from, now?Originally Posted by Meelobee
500+ full albums
4,000+ video games
Mine doesn't survive crank either, at 9.7v, tested with a 4 ft peice of 8ga from the battery terminal. =\
Ah well.
You can wire a switch to the ACC wire that is a 3 position one is normal acc, aone always on, and off.Originally Posted by Meelobee
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
Sorry for the late reply, currently I use a standard 12v outlet in the boot.Originally Posted by ITL
Can you explain that a bit more? It sounds like something I want.Originally Posted by WebDog
I assume by boot you mean trunk. You ought to try running directly from the battery.Originally Posted by Meelobee
Let me try. The three position switch would allow the following scenarios:Originally Posted by Meelobee
1) Run PC anytime, no matter if car is on or off. You control startup/shutdown.
2) Normal ACC: Ignition controls startup/shutdown.
3) PC is always off.
Wire 1 will be constant 12V. Wire 2 will be switched 12V. Wire 3 will be common ground.
This is something I need to implement myself. I'm just spinning my wheels trying to figure out the best place to discreetly, yet conveniently mount the switch.
500+ full albums
4,000+ video games
