Results 1 to 10 of 10
Thread: PSU Stress Test
    Jul 2000
    Hampton, GA , USA
    Post PSU Stress Test
    Hey I am putting in together an mp3 player for my truck and I have a 230 Watt AT Power supply and was wanting to know how much that I might be able to hook up to this without killing it.
    Currently I have a CDrom, 27GB, 40GB, fan for the heatsink, and powering the mobo running a 166MMX underclocked to 133. I need to see about adding an extra fan for more ventalation. Suppose I could add an 80mm or 92mm with out too much of a problem?
    System Status - Starting Over
    Computer: None
    Vehicle: Silver 2002 Malibu
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    Post
    you car run your fans from dc 12v straight from the car. Not that they draw much current, but every little bit helps
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Aug 1999
    Upper Marlboro, MD 20772
    Post
    Or he can get an AT style psu from arise if his mb is AT. Notice all the gadget my box has and everything is powered by that small 65watt arise psu.
    BTW, mike, i just noticed your sig said you are still running c2, have u tried c3.
    abcd-1
    Oct 2001
    Ontario, Canada
    Post
    230W supply will run 3 times what you currently have, I wouldn't worry about it at all.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Question
    Just a question, why is your CPU underclocked?
    Oct 2001
    Ontario, Canada
    Post
    my guess would be that he wanted to use less power, and if all you're playing is MP3s then P133 will do you just fine.
    Jul 2000
    Hampton, GA , USA
    Post
    Well actually, its underclocked by mistake. Its an older mobo, and trying to find the right jumper settings for the FSB is a little tricky some times. But as Telek mentioned it is using less power. My only fear was hooking up the HD's and CD-Rom and worry about overloading the PSU.
    As of right now, the PSU only has 3 Molex type connectors and as of right now they are all in use. Thats why I was a little worried about adding more load to the PSU.
    Computer: None
    Oct 2001
    Ontario, Canada
    Post
    To give you an idea, I'm running a 1.4Ghz Athlon, 2 7200rpm hard drives, a burner, a cdrom, sound blaster 128, ethernet, tv capture card, ATI AiW 128, all off a 200W power supply and I don't think I've even taxed it. I've had that setup with 4 hard drives plugged in and ran without a problem.
    So I think your 133 with a 220W PS is in no danger
    Apr 2001
    Portland OR
    Post
    Originally posted by xanimal:
    <STRONG>Well actually, its underclocked by mistake. </STRONG>
    I don't think it is a bad idea at all to underclock your cpu. You can save several watts doing so. I had a 233 underclocked to 133 until someone stole it. The laptop power supplies I was useing didn't get hot after that.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    moahdib's Avatar
    Jul 2000
    Post
    Telek&gt; I can't believe your PSU can handle all that stuff....
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
