Results 1 to 6 of 6
Thread: m1 or p1900??
    Nov 2005
    m1 or p1900??
    ok, what should i do?
    i have this case - Travla Mini-ITX C138 Aluminium Case with 120W PSU
    now i was planning to buy the M1-ATX 90Wbut i have been told the Carnetix CNX-P1900 140W Dual Output Power Regulator would be better. I no that the p1900 has alot more power but is it a better option ??
    cheerz
    Nem
    Elsewhere
    YOu already have power supply. The Carnetix is designed to work with the power supply you already have.
    The M1 is a replacement for what you already have.
    Understand that the Carnetix only regulates the power from the battery (which will fluctuate) to provide a constant voltage to a device that requires it, like the PSU in your Travala.
    How about the Wiki?
    Nov 2005
    yar i no the carnetix is a regulator but which is the better way of doing things, psu and regulator or new psu ??
    Nov 2003
    Marietta, GA
    NemesiS153,
    Hmm....I kinda like the P1900 myself.....
    Seriously, what processor are you running in your C138? If it's a P4 you may be better off with the P1900. Just my 2 cents....
    MikeH
    Nov 2005
    heres my rig
    Via Epia M10000 Motherboard
    512 pc2700 ram
    60 gig 2.5 HDD
    slim line dvd/cdrw
    linitx plus touchscreen
    bu-303 gps
    Elsewhere
    Quote Originally Posted by MikeH
    Yeah, but you're more than a little biased.
    How about the Wiki?
  1. Does M1 not prevent battery drain while PC is on?
    By uncrase in forum Power Supplies
    Last Post: 10-29-2005, 04:59 PM
  2. m1 questions
    By cyrax83 in forum Power Supplies
    Last Post: 08-27-2005, 08:08 AM
  3. Carnetix p1900 and Travla c138 120watt?
    By john_draws in forum Power Supplies
    Last Post: 05-27-2005, 01:42 AM
  4. p1900 is perfect -except for one quirk:
    By crazymadbastard in forum Power Supplies
    Last Post: 05-24-2005, 07:48 PM
  5. P1900 Hookup Help
    By maxipad96 in forum MacCar
    Last Post: 05-12-2005, 10:22 AM
