Results 1 to 10 of 15
Thread: What PSU? P4@3Ghz
    Jun 2005
    What PSU? P4@3Ghz
    Hi,
    What PSU would you choose to power a P4 system and to be sure to avoid any problems with power consumption?
    I did a power simulation of my system and I need at least 200W, so I'd like to have a PSU able to give me at least 300W. Is there any DC-DC Psu able to do that or do I have to go on an inverter solution and use a normal ATX PSU of a dekstop pc?
    Ste
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    look into dsatx i think its called? honestly a 3.0 p4 is overkill for a car. i personally think anything over 2.0ghz is overkill. between 1 to 1.5ghz is good. and you can use smaller psus and cases and they are more stable less heat and all that good stuff.
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Total wattage doesn't mean any ****.
    From the power calculator you use, write down how many amp on each power rail (12v, 5v, 3.3v) and compare it to the spec of the PSU. Currently DSATX is the most powerfull one.
    If your calculation required 15A or so on 5V rail, your only choice is INVERTER. DSATX max out at 10 or 12A I can't remember.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Registered User Nicorolla's Avatar
    NB,Canada
    well, you already have one problem
    P4 3ghz = massive power consumption, no getting around that
    if you do choose to go that route, going with a standard PSU and inverter is ur only way.
    if you want high processing power with low power consumption go with either Athlon XP-M or Pentium M chips. They are a bit more money tho
    Nov 2005
    Quote Originally Posted by Nicorolla
    Depends, I got a XP-M 2400+ off Ebay for $25 and it will clock 10 x 210 easily. It will also easily scale down to 1.1v at 1000mhz which is all I really need in the car anyway. 8rdavcore is a great program for running AMD speed on a as needed basis.
    The P-M are more expensive.
    Nov 2005
    The northwood p4s consume exceptionally low amounts of power as well. Though 800fsb versions are hard to come by, they run on ebay about the same price as cheaper prescotts. They're not available in Socket T though (afaik).
    Case in point, I was able to overclock a celeron northwood 20% (2.26ghz to 2.80ghz). And at the same time I *lowered* the voltage in the process. So it runs cooler, faster, consumes less power, and just as stable than stock.
    Nov 2005
    Quote Originally Posted by jerico2day
    Yep. A [CPU work] / [watt] graph would be best to determine which processor is more efficient.
    My northwood will run a 650mhz overclock on stock voltage (as my MB does not have adjustment).
    NB,Canada
    i can't wait t'ill pentium m based architecture becomes mainstream and at affordable prices. I've seen some articles about the M chip overclocked beating the top end desktop processors from both AMD and Intel... and still drawing only like 20w or 30w, don't remeber exactly.
    The ultimate carPC (right now) would be one of those new Aopen desktop boards that supports the Pentium-M chip and a decent mid end video card.
    If i had tones of money to dish out, i would buy one in a hardbeat
    Dylan98R/T - sorry i wasn't very clear, when i meant more expensive i meant price/performance/efficiency wize, altho i'll have to agree that the XP-M is the best bang for the buck when it comes to this. I'm just curious, how many amps is ur whole carPC drawing at full load with that chip?
    Nov 2005
    I agree if you are buying NEW hardware, the mobile version of any chip is more expensive. But I don't know why anyone would want to buy the most current hardware for a carPC anyway. Let that stuff become 6 months old and the price is half.
    I paid $90 for a used P4 2.66 and $25 for a used XP-M 2400+. The XP-M is comparable in performance to the P4 at lower wattage. Especially given I can use 8rdavcore on my M7NCG400 and dynamically run the XP-M at lower than OEM voltage (I can hit 1.1v on mine) and lower speed. I'd like to compare the P4 with XP-M but I can't undervolt my P4 MB. The northwood is an efficient chip but for several reasons the XP-M is going in the car.
    Mine system isn't together completely, but afterwords I'll have some system draw numbers at different speeds.
    NB,Canada
    Quote Originally Posted by Dylan98R/T
    yeah i'm very curious to see what kind of numbers you can get, everyone keeps talking about this is more efficient that this and **** like that but they don't have numbers to compare. What you have there is "the" way to go with a carPC price/performance/efficiency wize. Unfortunate for me i never concidered power efficiency until a while after i made my carPC. I'm just waiting for new technologies come along, like the P-M but cheaper... and made by AMD
    Until then, i'll just have to torture my yellow top batt.
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
    By baboojoon in forum General Hardware Discussion
    Last Post: 07-08-2005, 12:27 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
