hi I can't remember which one you should use, but you can check the older designs to see which is the correct one.....
Hi, I'm trying to build a Sproggy MK2.6, and I can't figure out which piece to order for the "T6"
on the Part List PDF, is says :
T6 (Q4339-B) ----- Part Number: Q4338-B
okay, so there's a slight difference in the two numbers one having a "8-B" suffix while the other has a "9-B" suffix.
On the coilcraft website, they mention both the Q4339-B and the Q4338-B as ones that they connot sample because of "hobbyist building mp3 players".
the spec sheets for these are WAY different, so which is the right one to buy???
this one:
http://www.coilcraft.com/q4339.html
or this one:
http://www.coilcraft.com/q4338.html
Thanks a lot,
-Miles
Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
If at first you don't succeed.........
destroy all evidence you tried
for info on t6369c LCD or Presslab's powersupply check:
http://www.namms.tk <=updated!!
Thanks a lot... BTW, it's the Q4339-B for anyone who's interested
-Miles
