Results 1 to 6 of 6
Thread: Need Advice for a Dell SX270 setup
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Sup yaa, I know some of yaa have used a Dell SX270 or 260 as your main Carputer becaused I searched. What did you use to power it? If a power inverter, How did the modified sine affect it?
    Advice welcomed. I Did.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    i have a gx270 which I believe is similar to the sx except for the form factor. I'm using a 250w inverter and haven't had any problems.
    btw its a p4 3.2 2gb ram
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Jun 2005
    Power supply is different
    The SX model used an external brick for it's power supply, the GX was a standard power cable that connected to the back like most PC's. The external brick should not affect connecting to a inverter but I have not done that. My experience is with the SX series, not with installing it into a car. The power brick in question is pretty big and difficult to manage with the power cable and all.
    God made me the geek I am, the freak part came from watching RHPS too many times and drinking Re-Animator fuid at Con's too much.
    Jul 2005
    Bronx, NY
    I just want to know before I buy a 800 watt inverter.
    Looking to get this project installed before march.
    Jul 2005
    Bronx, NY
    Anyone with other ideas? I was looking into the CarPC Platinum Power Controller V.25 and Coleman 400 watt Power inverter for its features.
    Oct 2004
    NY
    the 400 watt one should be o.k., the 800 watt one would give you more than enough, which isn't always a bad thing.... I'd probably lean that way....
    modified sine waves no problem... any inverter will work fine...
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-14-2010, 12:17 AM
  2. carputer setup. advice / last minute check before ordering.
    By tdevil in forum General Hardware Discussion
    Last Post: 01-29-2005, 07:59 PM
  3. CarPC Setup Advice...
    By mattwz in forum Newbie
    Last Post: 11-23-2004, 11:41 PM
  4. Advice on a Setup (kinda long)
    By f250crewcab in forum Newbie
    Last Post: 08-20-2004, 06:06 AM
  5. Advice on Setup...
    By blackout03specv in forum Newbie
    Last Post: 06-29-2004, 10:36 PM
