Ok now I am confused. One thing I am not confused about is that my board does not need a power good (whew).
I have 2 case fans (one connected to the motherboard and one connected to the power cable). I also have a CPU fan, laptop hard drive, DVD rom and floppy drive.
I got frustrated and I unhooked everything but the CPU fan and the case fan that is connected to the motherboard. I connected the Arise to the motherboard and that is it.
I used the PSU that is powering the Arise and plugged in the case fan and laptop HD to it as if I was using it. Can you believe this it powered up with nothing connected to the power cables of the Arise?
Were all of these things connected to the Arise too much for it, causing it to not power up?
I know I can plug the two case fans to the 12v dc of the car but what else can I plug into the unregulated 12v dc of the car with messing anything up? Obviously the Arise 865v wouldn’t run everything that everyone said it would.
Jeff
Now I went back to check everything out and the computer was dead but the fans were spinning that were pluged into the ac-dc PSU. I don't know whats up??????????
[ 10-20-2001: Message edited by: jssaggie ]
I have been playing with everything to see what the DC_DC PSU doesn't like. I pluged evrything in one at a time to see what causes the problem and when I pluged in teh HD it wouldn't Power up. I can plug the HD by itseldf and it will not work. I am really thinking that the AC PSU can't handle the amount of 12 v amps needed that is what is causing the DC DC PSU to not pwoer up. The laptop HD is a toshiba (+5 v dc .7a). Sorry for the long postsjust hope to give enough info to fiq out the problem. I have a fluke but I don't know how to check the amps just volts...LOL don't know much about electronics>>>
I fell like I am talking to myself here!!!
Well I got it to work but I had to plug the AC-DC power supply into an old motherboard in order to get enough power to the Arise to get it all to power up. After using the computer for a while i heard a pop in the AC PSU and found that I blew the 250W PSU. What would cause that to happen?
[ 10-21-2001: Message edited by: jssaggie ]
LinkBack URL
About LinkBacks
