Results 1 to 10 of 11
Thread: pic of m1-atx
    Nov 2005
    pic of m1-atx
    hey Im trying to hook up my m1-atx power supply and I cant get it to work right. I need some pics of you alls up and running I just need a quick shot of everything connected and runingon the power supply.
    Thanks Bryan
    Nov 2005
    I have the manual but it dosent show everything. So, I need a pic of it up and running to see what I have wrong if I have anything wrong
    Jan 2004
    California
    I have no pics, but as I've just installed mine a few days ago, perhaps I can help.
    PSU to motherboard
    Doesn't matter which way, although I have the molex connectors coming from the PSU side.
    Powerswitch
    You can leave your case/mb switch plugged in, the PSU will still function (ignition on/off), and then you can manually power on/off the PC.
    Power leads
    (J11) White - Unswitched
    (J12) Red - Switched
    (j13) Black - Ground
    Is this what you're looking for? Other installation questions?
    Nov 2005
    yea my power supply came with no conectors just the power wires. Im trying to find out what connectors I need I went to radioshack and looked for some 2 pin conectors they dont have any. and I need something to look at to c what I can supstute. I have 12 volt power coming from my distrbution block for the amp and the switched is coming from the radio harness and so is the ground. my queston is do I have to have any thing else hooked up besides those wires like the led the switch etc. I have a switch on my motherboard to turn it on.
    Newbie recompiler's Avatar
    Dec 2005
    New Jersey
    The power supply is supposed to be managing the MOBO, I think I have the manual in a PDF I can post. You need a 3rd wire going to ignition to the PS knows when the car is turned on and off to control the MOBO.
    2004 Eclipse GTS v6 Turbo, NOS
    Plantronic in-dash LCD
    Via Epia M2 1200 with WiFi and CF Microdrives
    OBD2
    Rino 120 GPS
    Nov 2005
    yea I did that but where does the powersupply hook up to the mb and I need a 2 pin connector for that right I think I have the pdf. Another question on the pdf it says that the remote wire for the amp connects to the powersupply but I dont see where it connects anybody connected on to it?
    Dec 2005
    New Jersey
    Yes you do need 2 wires. Your best bet may be putting that together yourself. I can snap a few pics of the conenctions in the morning. Remote wire for the amp? I have the power supply connected to the car by 3 wires (+,-, ignition).
    OBD2
    Rino 120 GPS
    Nov 2005
    Recompiler That would be nice if you would take a pic
    thanks Bryan
    Jan 2004
    California
    Quote Originally Posted by onlystunna
    Sounds like you're good to go. Shouldn't need anything else. I'm running mine with only the wires I listed above.
    Dec 2005
    New Jersey
    All the pics you need should be in this photo set.
    http://flickr.com/photos/recompiler/tags/carputer/
    If you need more tell me specifically what you want me to zoom in on or describe.
    OBD2
    Rino 120 GPS
  1. m1 atx is killing my battery on taxi mode
    By cass944 in forum Power Supplies
    Last Post: 11-23-2005, 10:54 AM
  2. M1 ATX, hangs. Help a swede in need.
    By Biograph1001 in forum Power Supplies
    Last Post: 11-18-2005, 10:01 PM
  3. m1 atx
    By corsab in forum Power Supplies
    Last Post: 08-21-2005, 09:03 PM
  4. m1 atx 90watt...is it for me?
    By psycos in forum Power Supplies
    Last Post: 08-13-2005, 12:06 PM
  5. Wanted. M1 ATX Lead..
    By CdRsKuLL in forum Classified Archive
    Last Post: 08-12-2005, 10:57 PM
