Results 1 to 7 of 7
Thread: Compaq Evo D510S Power supply
    Philly
    Hey all,
    I got a Compaq EVO D510S(d51S/p2.4/80/2.00) it's a P4 2.4Ghz, 2 Gigs of ram and 80 gig hard drive. I wanted to convert the power supply connector to a 20 pin, I've seen this post but I don't know if this will work with a 2.4ghz processor? also what size power supply can I get for this motherboard once I convert it to 20 pins?? I guess I would probably need about 200-250 watts!?!?
    or should I get a Power inverter(ac/dc)?
    Newbie 106-Quiksilver's Avatar
    Jul 2005
    IOW
    yeah i think anything over 150w you should be looking at an inverter, isn't a Compaq EVO D510S a laptop?
    In Progress... Putting my interior back together
    Philly
    NO it's a desktop, small format.
    well here's the wierd thing, the compaq ps on the system is a 175w max. But when I calculate everything in the system it comes out to be using 250w or more?? wtf!?!? if I can get away with a 175 can I just put a 200w power supply?
    sorry for the bother.
    Philly
    bump
    Dec 2005
    You ever figure anything out? I have the same PC wanting to make it work with the Opus PSU I bought.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Look at the Compaq PSU to see what are the output capacity. How many amp on each power rail (if it output are 3.3V, 5.0V, 12V ..... ) and compare it to the Opus or DSATX. I think you better off with the DSATX.
    As for converting the ATX 20 pin connector. If there is a vailable to buy, buy it (maybe not available). Otherwise, use a meter and do the conversion yourself.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2005
    I can't find any info whatso ever so I think I am gonna go the inverter route. Don't want to risk blowing the mobo
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. 440 Watt Power Supply
    By zootjeff in forum Power Supplies
    Last Post: 01-12-2006, 02:14 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
