Results 1 to 7 of 7
Thread: Powering shuttle ST20G5. OPUS or INVERTER??
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Hey guys!
    I am thinking of going for the Shuttle XPC ST20G5 for my carputer.I also had in mind using an inverter and the carpc ez 2.5 SDC.
    However, i've been searching in the forum and found a lot of members saying they use opus to power their shuttles. I am kinda' confused.
    What is the best option? Inverter + SDC OR OPUS??
    From what i have read you have to buy a special opus and replace ur shuttle psu.However, if you are going for the inverter and sdc, the atx connector is different.This won't be a problem, would it? i think it wont as the SDC would be connected to the "power on/off" jumper on shuttle's motherboard rite?
    Plus, will the opus have enough juice to power the shuttle ST20G5?
    I am planning on having a powerful shuttle so it wont need upgrading for some time.And it will have a webcam,gps,wifi g, bluetooth, all these usb.
    What do you guys think personally? INVERTER or OPUS?? PROs and CONs?
    THANKS IN ADVANCE guys!!
    Elsewhere
    Your'e going to need an inverter. And do you REALLY need an Athlon64 in the car.
    How about the Wiki?
    Aug 2006
    Seattle
    Quote Originally Posted by DarquePervert View Post
    Is there a DC - DC Psu that will work with this system. I'm running into major line noise and feedback from my inverter. and I have torn my install apart more then once traking it down.
    Elsewhere
    Quote Originally Posted by mustangwhore View Post
    Read this: FAQ: Will <insert PSU model> Power Supply work with my system?
    How about the Wiki?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Yes, your first step to making an informed power supply purchase is to calculate the amount of power draw your system will create.
    Give us a number, we will give you an answer.
    Aug 2006
    Seattle
    It seems to work
    I bought a opus 150 and it seems to power the same unit just fine. I've been up and running with no problems for almost 2 weeks.
    I'm running the following
    AMD X2 3500+
    512 mem
    DVDR / CDR Combo
    2 500gig drives
    4 Usb ports in uses.
    The PSU does'nt fit in the stock location tho They changed the MB config with the memory slot right below. I guess they are more designed for the older models. I just mounted it on the reverse side where the PCI Slots are.
    Elsewhere
    Quote Originally Posted by hohenyi View Post
    __________________________________________________
    Help please I'm going to much reading one say this the other say that. Can you please advice which DC to DC PSU can i use to power up the following PC:-
    It will help you achieve a baseline.
    How about the Wiki?
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Opus 150 and PW-70a powering one carputer
    By Altimat in forum Power Supplies
    Last Post: 05-19-2004, 12:43 PM
  3. Strange problem powering xenarc from 90w Opus :(
    By Brettster in forum LCD/Display
    Last Post: 05-11-2004, 06:19 AM
  4. QUICK REPLY: Opus PSU Bracket for Shuttle XPC
    By G35Pimp in forum Power Supplies
    Last Post: 01-15-2004, 12:34 AM
  5. Opus 150 PS available for Shuttle XPC
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 09:50 PM
