Something like this:
13.8V Power Supply
ive done a search, and maybe im just stupid but i couldnt find anything on the topic.
is there anyway i can test out my MPX-ITX-CD (vehicle carputer case w/ psu stuff already put in it) inside without having to install it into a car? has anybody done this before?
i also have the Mp3car MTSVO-SC Fully motorized VGA Touch Screen, is there anyway i can power that indoors as well?
thanks for the help
via epia sp13000 mobo
512mb ddr ultra slim ram
100 gig hdd
mp3car in-dash TS
much more to come!
13.8V Power Supply
would that hsit work on a opus?
The power supply??
Yes, it will power just about any car related items. That's what it's designed for.
DF
Get a car battery charger and a gel cell battery (12 volt).
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
Damn 25 amps. Sweet. I just got done modifing a 400 watt computer power supply so i could use the 12 volt line from it. It has 27 amps on the 12volt line![]()
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
thank you!
100 gig hdd
mp3car in-dash TS
much more to come!
How did you go about the modification of the PSU? did you basically scrap the AC side change the transformers and leave the rest? just interested in trying this outOriginally Posted by pRoFiT
cheers
Soltek Qbic P4 3.4G - 1GB RAM - Lilliput 8"
1974 Ford Mk1 Escort
Well you don't want to scrap the AC side cause the idea here is to use it in the house for testing. All you need to do is jumper the turn on pin on the ATX connector or put a switch on it. Other things you might want to do is get rid of any unwanted wires and for stabilities sake put a few load resistors on the outputs you aren't going to use. Sorta depends on the power supply and what the quality is. An ATX PSU will give you a good regulated 12V but the supply I mentioned will give you 13.8V which is more like the car environment. And untill Dec 11th you can get 30% off if you can get an RS employee to share a friends and family coupon with you. It's basically an employee appreciation thing where they get coupons to hand out to friends & family and they will get the employee discount.
DF
In the FAQ Emporium: Powering your Car PC when it's not in the car
Want to:
