Opus point-of-load PSU will likely do what you need.
Hey guys
My plan is to have laptop PC, but i think i will need a seperate PSU to give me power for accesories (like hdd). I was going to control startup with modded power button, and shutdown with battery standby so i dont really need a SDC.
What PSU should i get, where i will just wire it to ACC relay and use it to power external drives/hubs/and my 7" TS. Is M1 ATX overkill?
Progress 50%
Next Step: Making Enclosure, Hard Wiring PSU
Thinkpad 1Ghz P3
256MB RAM
Lilliput Motorised
80GB 3.5"
seems like a good simple asolution, i hadnt seen that, its great
BUT im a touch worried abouyt 15W
My lilliput is probably around 10W, leaving only 5W. That 5W needs to do an external 3.5" HDD at a bare minimum, but i would like excess for later additions like hubs. Will that 15W POL be enough guys?
Progress 50%
Thinkpad 1Ghz P3
256MB RAM
Lilliput Motorised
80GB 3.5"
i dont think 15W is enough for lilliput, hdd, dvd drive hub etc.
What should i get? M1-ATX? Give me an answer somebody?
Progress 50%
Thinkpad 1Ghz P3
256MB RAM
Lilliput Motorised
80GB 3.5"
The HD i just got draws 14.5w max. So my instincts tell me NO.Originally Posted by McGinty
the m1-atx provides 90 watts of power and I believe there is also a 90 watt opus. I have not seen or heard of a 15 watts psu as of yet.
the 3.5 drive might be a little much on the 12v rail of the m1-atx. better off going with a m2-atx or an opus.
