OK let's see.
LM2587:
Pin 5 is Vin, it should go to +12V
Pin 4 is an output, it does the switching (pulsing)and it should go to pin 2 of the transformer's primary, the other pin of the transformer should go to +12V, just like pin 5 does.
Pin 2 is a feedback input, it monitors the 12+ output from the transformer/diode/capacitor chain, you should be getting @ +12 volts from it.
I suggest you double check your wiring and component polarity around the regulator.
Good luck!
[ 01-27-2002: Message edited by: Miel Gibson ]
LinkBack URL
About LinkBacks
