Results 1 to 2 of 2
Thread: Notebook startup/shutdown controler
    May 2005
    I was thinking - if I have a laptop running off a standard inverter, I could wire up a simple switch to turn the laptop on and off by tapping into the laptop's power switch.
    Now, maybe some of the electronics gurus on this site can help me.
    I want to build a startup/shutdown controler for a laptop that does this:
    Senses when 12V is present at the cigarette lighter (where I have the inverter plugged in. This is turned off when the car is off, on when the car is on) momentarily shorts out the leads going to the laptop power switch (just like pressing the button) and turns it on (could resume from hibernate depending on the laptop's configuration)
    When the 12V is lost at the lighter socket by turning off the car, the controler would momantarily short the power button leads causing the laptop to hibernate or turn off (remember, the laptop can run from the battery)
    Now, with 12v not being present at the lighter socket, the controler could run from the laptop's usb port at 5v, to provide the shutdown
    I have absolutely no idea how this would work, but I would be willing to spend up to $50CDN to have someone design and build a reliable controler. (just a controler, not a power adapter like the M1)
    I cannot afford to buy a complete carputer at this time, but I have a lead on a laptop with a dead display that would work perfectly for this.
    Thanks!
    Newbie 106-Quiksilver's Avatar
    Jul 2005
    IOW
    I am in a similar situation and am in the final stages of testing my laptop carpc setup. I am using this adaptor (http://www.maplin.co.uk/Module.aspx?...ldID=&doy=6m12), i'm planning on removing the cigarette lighter plug and re-wiring it into the car's ignition live circuit. The laptop will then always be on charge when the car is running. I have set the powersave options on the laptop so that the system goes onto standby after 1min when running on battery. I have found that the battery will last several days with the system on standby, and will commence charging again when I get back in the car and turn the ignition on. Also solves getting fast boot times, as my laptop returns from standby in less than a second when i tap the touchscreen after turning the ignition. As long as the in dash touchscreen and amps will run of ignition live as well i hopefully shouldn't need a startup/shutdown controller. I'll let you know if i get any problems.
    In Progress... Putting my interior back together
  1. Bracket to hold Notebook Computer in Car
    By vince123123 in forum General Hardware Discussion
    Last Post: 05-22-2005, 11:56 PM
  2. My notebook plan (long read) please advise.
    By mpfjr in forum General Hardware Discussion
    Last Post: 08-25-2004, 04:47 PM
  3. FS: Notebook Pro Surge Protector
    By buildfromscratc in forum Classified Archive
    Last Post: 08-14-2004, 06:24 PM
  4. Creative Inspire 5.1 Digital 5500 on notebook
    By hkp23 in forum General Hardware Discussion
    Last Post: 04-03-2004, 09:10 PM
  5. use of TFT screen from a notebook ?
    By 8klepperke in forum LCD/Display
    Last Post: 02-12-2003, 10:23 PM
