Results 1 to 6 of 6
Thread: 12V Power Supply with Isolated Ground?
    Mar 2005
    Where or how would I get a 12V DC-DC power supply that has an isolated ground? The problem that I'm running into is a video converter that I am using (Component to RGBS) needs to have a ground isolated from the video ground (car body ground) otherwise there is no video output.
    I am using an inverter and the original AC-DC power supply for the converter unit, but I get interference in the picture when the car is off or on. I am assuming that it's the AC-DC power supply is causing the interference now. So any options here?
    Variable Bitrate viper24's Avatar
    Oct 2005
    Sacramento, CA
    wow, good luck! that seems like a tough problem...
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Mar 2005
    Quote Originally Posted by viper24
    Yeah, I know...hey, a fellow mobile modded Xbox owner
    Quote Originally Posted by proph
    Sweet...but $165 is a bit steep. I'll do one more test to see if the AC-DC adapter is the issue for sure, before I shell out that kind of cash just to get rid of a bit of interference.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    How much power does it need? maybe use a separate battery that you take into the house to charge every now and then - but a messy solution.
    Fusion Brain Creator
    Mar 2005
    convert to AC, run through isolation transformer, convert to DC
  1. FS: PC Power and Cooling 12V DC-DC ATX Power Supply
    By Mad Jad in forum Classified Archive
    Last Post: 07-24-2006, 11:38 PM
  2. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  3. Inexpensive DC-DC power supply for 12V only?
    By P4_2.66GHz in forum Power Supplies
    Last Post: 11-20-2004, 10:17 PM
  4. FS: 12V 70W AT Power Supply
    By bodiby in forum Classified Archive
    Last Post: 08-10-2003, 09:05 AM
  5. 12v dc-dc atx power supply
    By plasmadis in forum General Hardware Discussion
    Last Post: 06-28-2000, 05:51 AM
