Results 1 to 10 of 16
Thread: Will M1-ATX power this?
    Low Bitrate simbot41's Avatar
    Dec 2005
    1ghz Celeron
    1 20 gb HDD
    1 LAN Card
    512mb RAM
    1 Geforce 440 64mb VRAM
    Can I power this with M1-ATX and also can computer nerd/circuitry noob do this on his own?
    Cheers
    Simon
    Sep 2005
    scotland
    no the m1 will not power this the m1 is 90 watt
    you will need more like the opus for this set up
    and yes you can do it
    its not that hard
    Dec 2005
    Really? Bugger now I am conflicted. a couple of people/sites have said it will and some have said it won't. Anyway of working this out for myself?
    What could I take out of the comp so it could be powered?
    Cheers
    Elsewhere
    Search for a power calculator here. There are several. None are accurate, but they will give you a balpark figure.
    If your proposed setup is still over the 90w max of the MQ-ATX, then look into an Opus 120w, an Opus 150w or a DSATX 220w.
    Good luck.
    How about the Wiki?
    Dec 2005
    Yeah see thats the issue. The power supply says it can handle celeron I,II,III but only in certain platforms.
    Two of the calculators are saying 170 and 165w so I have to get under 150 and go with Opus.
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    I run a 1.4ghz celeron, 512ddr, 120g 7200rpm hdd, wifi card, and 4 usb devices off an M1-ATX ok.
    Dec 2002
    Montreal, Quebec
    And, theres no way those components are hitting 165w... check out the thread I posted recently about the actual power consumption of my devices:
    http://mp3car.com/vbulletin/showthread.php?t=63865
    Dec 2005
    Are you serious fusion-one?
    So my 1ghz Celeron with no USB devices, no wifi will work a treat with this power supply? I really really want to get one but I thought I was stuffed. I am an aussie you see. The Opus 150w costs $279 aussie dollars. The M1-atx is only $135.
    Just to check again I can do this?
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by Fusion-One
    I run an Epia 1.3Ghz, Xenarc touchscreen, 80GB 2.5" HDD, 512ddr, and five USB devices all powered from M1-ATX and have never had any problems.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    Dec 2005
    Oh this is great. Ok so I am going to defiently get an M1-atx power supply then. So ITL you even run your LCD screen off the computer (like a normal computer screen I suppose)
  1. atx POWER SUPPLY?
    By nickweb in forum Newbie
    Last Post: 09-26-2005, 05:39 AM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  3. full ATX mobo and req. power
    By fishy in forum Power Supplies
    Last Post: 10-13-2004, 01:53 AM
  4. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
  5. ATX power
    By BooJew in forum General Hardware Discussion
    Last Post: 07-07-2000, 06:45 PM
