Actaully Jeff's is quite sufficient enough. That's great that people make and sell this stuff. Maybe I'll try to get one from him after I get my system running.
I need some help, I am going to have the Keypower power supply wired straight to the battery like a stereo amp.
In Windows XP there is a option to hibernate, ask me what to do, shutdown, etc...
If I choose Shutdown, is there a simple way to design a circuit that connects the power switch leads for a second when it senses 12 volts and then connects the leads again for 1 sec when the 12 volt load drops?
Thanks.
Basically a addon to Jeffs shutdown controller that also pushes the power button on a 12 volt on sense, ann not just the 12 volt off sense.
[ 01-29-2002: Message edited by: LW 317537 ]
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
Where would I find the shutdown controller you're speaking of? Sounds like I'm doing the same thing you are. I found an empty slot on my fuse row in my truck that has switched 12 volts and a 30 amp fuse. It would be cool to have a controller to turn on/off my computer. That would be even better than just hard wiring. Let me know where I can find info on this device.
Thanks,
Jesse
2001 Ranger XLT Off Road
Sony CDX-C910, Sony CDX-U303
Sony XA-300 USB->unilink adapter
In dash 5.8" LCD
Infinity Beta 3 way component set
4 - OZ Audio 250L 10" subs
2 Sony XES-M1's, Sony XES-M3
Esoteric Audio wiring
Toshiba 7020CT laptop with DVD docking station.
You can get the shutdown controller from Jeff. I just ordered one from him prebuilt for $33.00.
Here is the link: http://home.attbi.com/~zootjeff/shutdown/
-Leslie
