Results 1 to 10 of 13
Thread: Opus keeps powering the 5V molex rail even with the pc off...
    Tainted Love Cris's Avatar
    Romania
    Question Opus keeps powering the 5V molex rail even with the pc off...
    For a while I've noticed that the battery from the car is draining all of a sudden over night...So, I got a multimeter to see what was going on.
    It seems that the Opus keeps powering the 5V rail from the molex (I'm not talking about 5VSTB), even with the PC turned off from Windows, so when the PSU is in Idle state. For a clearer picture, the DVD is still powered after the PC is turned off from Windows. This should't happen...
    Has anybody experienced anything similar to this?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Common problem. I think there are three possibilities:
    1) Install an override switch to turn off battery power to opus.
    2) Install a relay to turn off battery power automatically
    3) I think Opus can modify the supply to turn off 5v rail.
    I don't like the 5v rail staying active either...but I don't want to be without the opus whilst it is modified (its out of the case anyway) so I opted for 1). I shut off the power if I'm leaving the car for any length of time.
    Romania
    Quote Originally Posted by pip
    Yeah, I was thinking about putting a switch in there too. What kind of switch did you go for?
    Constant Bitrate tangeray's Avatar
    Mar 2005
    Chino Valley, AZ (2 Hours north of Phoenix)
    I use a red guarded toggle switch. God Bless them... I dont use this exact one, but any standard double throw switch would work. My switch has a Red LED light in the head of the switch which lights up to show power is going through it......Here is a radio shack one..
    EDIT: This IS the exact switch I use...hahah...couldn't see it from the angle on the website.
    Tangeray
    Oct 2004
    NY
    if you don't want to have to use a switch.... you can use a relay to interupt the 5v when the 12v out goes down.... keeping everything automatic like
    Romania
    Thanks. Any specs on the button I should use in terms of Amps?
    Is this usual behaviour of the Opus? I mean keeping the 5V powered with the PSU in Idle mode? It doesn't make much sense...
    Oct 2004
    NY
    it's so if you do standby it comes back without loosing the usb stuff I think...
    any 12v relay should work.... you may need to group several 5v's togeather to do one relay, but this is fine as they all come from one rail anyway...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If 5V rail still power after off, something is wrong.
    By ATX standard, 5VSTB still on if power is apply to the PSU. There is some mod to cut that off as well. I remember rando did or post about that mod. You can use the same idea: use relay to cut off when 12V rail goes off like turbocad6 said.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Romania
    Quote Originally Posted by MatrixPC
    This is what I mean.
    With the PC shutt down (Opus in Idle state), I measured the 5V rail from the molex, and it read 5.some Volts. This shouldn't happen...
    I don't really care about the 5V STB, I didn't have a problem with 5V STB draining the battery the past year...
    Sep 2003
    Beach City, Socal
    Why not give Opus a call/email to see what they said.
    I am sure they offer to fix it for you.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. opus 12v rail???
    By futuresweets10 in forum Power Supplies
    Last Post: 11-16-2004, 05:56 PM
  4. 5V on USB header question w/ Opus 150W
    By beckkl in forum Power Supplies
    Last Post: 10-25-2004, 10:18 PM
  5. Powering USB 2.0 Hub off HDD +5v Rail - Any problems?
    By sq_geek in forum Power Supplies
    Last Post: 06-07-2004, 10:11 PM
