Results 11 to 20 of 23
Thread: playstation power supply??
  1. #11
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Post
    i thought that adapter is only for the ps1, since the new ps1's have the external power supply. if it will work with the original playstations then it might be a possible solution.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
  2. #12
    Feb 2000
    Rockford, IL (home), Southern IL (college)
    Post
    sorry, after looking into it some more i found that it does only work for the PSOne and not the older versions. ill be interested in hearing what happens with your research because i have an original Playstation (got it 1 week after they came out), and ive thought about throwing it in the car. again, sorry i was no help.
    2004 F-150
    Shuttle XPC, 80gig HD, Wireless Internet, DVD
    "How piMP3d is your ride??"
  3. #13
    Apr 2001
    Chicago Suburbs
    Post
    hey, no harm done. at least someone it putting some input into this thread... anyway, i pulled apart my psx last night, for about the 10th time since ive had it. and i have the 5 wire power supply. (5 wires from ps to main board)
    now, can i simply start tapping the outputs of the connectors with a multimeter and read what the voltages are. should i just tap 2 pins and read the voltages, or should i tap 1 pin and use a ground? note to everyone, there is no black wire, so i dont know which is used as a ground (if any).
    someone with some circuit testing experience help me get started.
    ~mike
  4. #14
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Post
    Rule of thumb, try the earth pin on the plug if you need a ground, if it has an earth that is.
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
  5. #15
    May 2001
    Cincinnati, Ohio
    Post
    Have you tried an inverter yet? I have a dreamcast running off an inverter and have zero noise.
  6. #16
    Apr 2001
    Chicago Suburbs
    Post
    rob... the plug is a 2 pin plug, with no third ground prong.
    adam... i have not tried an inverter yet. i was trying to make it a more compact installation, rather than having a psx sitting on the floor or back seat. maybe im just being difficult not wanting to accept that i might have to just use the inverter. ~~~sigh. but, maybe it will come down to that in the end.
    until next time...
    ~mike
  7. #17
    D2
    D2 is offline
    Oct 2001
    San Carlos, CA
    Post
    Oops, so much for me remembering how things looked the last time I pulled them apart. the info I have says that the 5 pins on the Original PlayStation motherboard from the internal power supply are;
    1 = +8V
    2 = GND
    3 = +3.3V
    4 = GND
    5 = RESET SW
    Enjoy!
    Still workin' on it.
    FUBA Homepage
  8. #18
    Apr 2001
    Chicago Suburbs
    Post
    SWEEEEEEET....
    thanks alot everyone. im gonna check out the pins to verify the voltages and currents this weekend sometime. hopefully my friend can give me some assistance with the circuit design. if that turns out to be a dead end, i may be coming back for some more assitance. when i get plans finished, i will be sure to post them in case anyone else decides to do some pointless stuff like me
    thanks again to all the have helped so far
    ~mike
  9. #19
    Apr 2001
    Chicago Suburbs
    Post
    alright, i have the voltage measurements...
    pin 1.. 7.5v
    pin 2.. gnd
    pin 3.. 3.6v
    pin 4.. gnd
    pin 5.. 1.5v
    pin 5 is the reset switch, and when the power is cut by the reset switch the psx reboots.
    how do i determine the current? i tried using the multimeter, like i did for the voltages (i moved the probes to the right spots on the multimeter). should current be measured inline. hopefully i can figure out a way to do that without messing up everything..
    thanks for anymore help..
    ~mike
  10. #20
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Post
    Yep, measure current inline.
    Rob
